Installing an after market amp/subs in a 03 g35 sedan with bose
Hey guys I've been looking for hours now & cant find a straight answer for this but i'm looking to install two 10" pioneer subs in & have them powered by an aftermarket amp. I currently have a kenwood deck installed with rca hook-ups in the back for SW, my question is do I need to uninstall the Bose stock amp or splice into these wires at all? and do my speakers requires this amp to still work? as well what would I need to install my amp/subs. Thank you!
For your situation, if the Kenwood deck has a subwoofer output, run the subwoofers off of that audio signal. You can use the bose amp's power-on signal wire, but I'd recommend using the remote amp power-on signal wire from the Kenwood directly so you're not splicing anything going to the bose amp/sub.
jbmw002
03-10-2016 12:06 PM
MilesToInfiniti
03-05-2016 11:27 AM
