Thread Tools | Search this Thread | Rate Thread | Display Modes |
DIY: Tokico D-Spec Extension for G35 Coupes
This is a pretty short DIY, but I wanted to add it now that some folks are getting these extensions with their D-Specs.
1. Jack up car and remove rear wheels. 2. Remove two nuts securing the dameners at the top of the rear wheel wells. Use a 12mm socket. 3. Compress the dampener by pulling down and pull toward you once free from the studs. I secured mine by letting it extend against the outer part of the wheel well such that I could access the hole easily. 4. Using a 1/2" bit, drill out the smaller of the two holes viewed within the shock mount hole. It should be the smaller hole that is closer to you (or exterior of the car). Be careful when drilling to keep the drill from 'jumping' far into the hole just when the drilling is nearly complete - you run some risk of damaging the rear panel cover. This can happen when the ears of the bit just break through the other side of the hole and catch on the metal. Just be sure to keep the drill steady as the hole is nearly complete and be ready for the snag. Although I didn't do this, you may want to install some tape, etc about 1/2" down the bit to act as a stopper. ![]() 5. Install the extension onto the rear strut and secure using a 14mm wrench. 6. Insert the extension through the 1/2" hole you just drilled and allow strut to seat in its appropriate position - DO NOT secure the two nuts just yet. You'll want to make sure the extensions routed themselves correctly first. ![]() 7. Fold down rear seat. 8. Remove baby seat Latch cover and plastic shroud. The shroud is removed by lifting up the rear (there is a lip on the back side) then slide it forward over the loop - this will make sense when you see it. 9. With a 12mm wrench, remove the bolt that secures the latch loop. 10. You should now be able to reach down through the latch hole with 1-2 fingers. If you reach toward the front of the car and slightly toward the exterior, you'll feel a layer of insulation. If you get underneath the insulation, you should feel the extension. Pull the extension end up and out of the Latch hole. If you don't feel the extension here, it may not be in the correct position. You may need to pull the dampener down and repeat step 6. ![]() 11. Adjust dampener as you wish - from inside the car .12. Replace plastic Latch shroud and cover. ![]() 13. Replace nuts inside fender well to secure dampener. 14. Repeat for other side. 15. Replace wheels and lower jack. 16. Enjoy your new found convenience! Side notes: You may find it easier to get the extension routed if someone is inside the car at the same time, but I didn't have that luxury when I installed mine. Also, I may go back and notch out the plastic shroud so the adjusters stick up a bit more vertically like Dovla did here: ![]() Thanks Dovla and James from CreativeAutoworks for your advice! Mike
__________________
2004 G35 Coupe 6mt|Laser Red|Factory Aero Kit|40% Huper Optik|Z Tube|Stillen CAB|Top Speed Headers|Zaino'd| Last edited by CrazyMike : 02-19-2006 at 11:19 PM. |
Thats a great write up, I wish more shock manufactures would follow suit.
We got about 10 more here in stock if anyone is interested.
__________________
Creative Autoworks www.creativeautoworks.com info@creativeautoworks.com 858-279-8900 Your Authorized Dealer for high quality wheels such as: DPE, HRE, iForged, Work, Maya, Volk, Zone Wheels, Modulare and Jline Forged Wheels!!! We also Carry: TEIN, BREMBO, STOPTECH, CUSCO, JIC, HKS... Etc |
Quote:
do those work on Megan coilovers by anychance?
Quote:
__________________
2004 G35C 6MT Brilliant Silver - Click name for drop down box to see homepage. |
Quote:
Sorry never got it, please resend. But we do have the H techs for both 350Z and G35's in stock and the extensions.
__________________
extensions for your d spec shocks?? are these like having EDFC except its manual and not controlled from the dash?? do they basically adjust dampening??? how much and do they only work w/ tokico d specs??
__________________
R C H 3 P |
Bump for a great DIY thread...
__________________
Florida G Club, President 2k5 LR G35 Coupe 6MT CrawfordZ Plenum, Headers, HFC | HKS TI | Carbonetics LSD | 4.083 FD Haltech | Osiris | JE, Eagle, JWT Cams | Performance Factory VQ35DE 312 rwhp |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
