2004.5 Infiniti G35x
Old Apr 24, 2024 | 05:30 PM
Alderkel's Avatar
G35x
Unhappy 2004.5 Infiniti G35x
Car randomly stopped shifting properly one day. Never hard shifted or missed a gear once. Car will shift 1-4 and then it stays in 4th gear until you put the vehicle in park and turn it off. Throws one code. U1000. CAN communication issue... Everything I'm reading points to the ECM/PCM. I had computer problems with it before. On really hot days the computer would overheat and cause all the lights on my dash to come on and none of the electronics would work. Car would go into limp mode. Thinking I can order a new one already programmed to my VIN and it'll fix my issue, but Idk. Any advice?
Old Apr 24, 2024 | 06:04 PM
Alderkel's Avatar
G35x
I drug pretty bad in a driveway one day and it stopped shifting after that. Makes me wonder if i damaged the valve body, or broke or disconnected a wire.
Old Apr 25, 2024 | 08:30 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd start with a visual inspection under the car for anything obvoous, verify you have the transmission harness that connects into the tranny with a single large plug and not the one with the 2 green 1 black plugs on the side of the transmission.
Old Apr 25, 2024 | 07:51 PM
ethannnnnn's Avatar
g35 stock except test pipes and hr injectors
what’s the difference if I may ask
Old Apr 25, 2024 | 10:53 PM
cleric670's Avatar
BANNED!!!
Difference is one has an accessible TCM and one it's inside the transmission. U1000 just means SOME computer is disconnected but it can be tricky to find out which one without the dealership Consult - II / III tool.
BlueMond
Jun 17, 2022 12:55 PM
jc68
V36 Engine, Exhaust, Drivetrain & FI
40
Feb 21, 2014 10:04 AM
Adam Robb
Drivetrain
Aug 19, 2012 05:34 PM
franz182
Drivetrain
Sep 20, 2010 09:02 PM
onewickedsvt
Feb 8, 2010 05:29 PM
