Rubbing sound from rear brake
Once my brakes warms up, I have a rubbing sound coming from my rear passenger side brake. I've replaced the pads, calipers and rotor. I've also tried adjusting the e brake tensioner too but the rubbing is still there. I'm out of ideas, anyone have this similar problem?
UPDATE: Alright, so I've eliminated possibility of the rubbing sound coming from the brake pads, caliper, rotor, e brake tensioner, brake dust plate and brake pad wear indicator. All of these have been replaced and new or adjusted.
I'm going replace the wheel bearing/hub assembly next. Will update as soon as I get that changed out...
I'm running stock 19" Rays lowered on Top Speed full coilovers. SPC camber and toe kit.
kinetek
08-03-2015 04:25 PM
