Scary movements?
Scary movements?
Recently I noticed while driving on the freeway my car starts to feel like it's floating side to side teeny bits, steering wheel is straight and not vibrating. Don't know about alignment but seems to go straight if I let the steering wheel go (at low speeds of course)
any ideas?
similar problems to this guy
http://www.dsmtuners.com/forums/hand...s-highway.html
any ideas?
if it feels like your front wheels kind of want to follow a crack in the road ever so slightly i also thought it might have been side winds feels similar but i jacked my car up and noticed some play in the wheel ended up being the front lower ball joint that is on the knuckle i pressed the old one out and the new one in and back to normal tight driving
Floating? Only time I ever experienced that feeling was when I was in dire need of new shocks on my last Z. KYBs are a good replacement shock for you G35! Find an independent brake/alignment shop in your area, suspensions are their business! While they're installing the shocks have them check out your suspension and alignment...Gary
