Camber arm eccentric bolt issue
It will not tighten all the way cuz the bolt may be too short and if forced it may stripped.. what year & model is your G? I think it was SPC part # 72260 if you have the RAS
http://www.spcalignment.com/index.ph...c&task=details
Sorry, I did forget to mention that I replaced the eccentric bolts with new ones after that was found and continue to have problems.
Getting ready to put on new tires and have it aligned again. After reviewing the spec sheet from the my last alignment, I began to suspect the driver side to be the problem since that is where the toe was out in the rear and caused the front to be off too. So I got under the car last night and checked the eccentric bolts. Both still look good (not stripped) and decided to see how tight the nut was on the bolt. I could move it with some effort but I wouldn't say it was super tight. I am taking it to a different place to have it aligned and I am going to ask them to mark everything when they get it set so I can see for myself if it moves again.
I drove ttrank's car solo
Received 1,486 Likes
on
If you search you'll find more but don't waste your time. As I stated in the linked thread I've had 5 Ichiba parts fail on me before I wised up and ran like hell from any of their products. Replace them asap with a reputable set, I went with Stillen and 6 years later they're still going strong with no issues.
edwinisdumb15
SOCAL Meetings & Events
09-02-2016 03:31 PM
Jiggs1219
02-25-2016 08:30 AM
