G35/350Z aftermarket coilover, springs and shocks spec's w/updates
#50
on
Originally Posted by LEK
can someone post the spring rate for the revised 350z oem springs? Thanks.
Oem springs G35 coupes 2005 only with oem 19’s only 350Z 2004.5/2005
Front:314 Rear:427
#51
#52
Tein H Tech + Tokico D vs Tein Basic
Hi everyone
seems like Tein H(350z) + Tokico D is a popular set up and i'm wondering how's the ride comparing with Tein Basic coilover?
from a price point Tein H runs around $150 ~ $189 and D spec is around $489 ~$550 so total is about $700ish and the Tein Basic is around $750 ~ $850ish..
so is Tein Basic a better way to go?? since the price is only a bit different... and it's ride height adjustable right?
oh.. and all i want to do to the sedan is to lower the car with 19" and give it a nicer look, better handling, stiffer ride and without using any camber kit.
thank you all and please forgive my english ...
e.
e.
#54
Originally Posted by Gsedan35
I think your asking about oem spring rates. Since all 2003 G35's were delivered with oem 17's or 18's, your car has 314/342 spring rates. If that's not what you wanted to know, please give me more detail.
#55
#56
Originally Posted by Gilley
What are the pros and cons of progressive spring rates vs. linear spring rates? What makes one better or worse than the other? When would you want to choose one over the other?
Progressive springs compress at a increasing (non-linear) rate. The first inch might compress at 384 pounds. The second inch might compress at 420 pounds... the third, 450... then 480... then 500... it progresses higher as you apply more pressure.
Progressive springs yield a more comfortable ride than linear springs because they are "softer" at their fully extended position. Progressive springs usually let a car roll a bit more than linear springs. Some times they can cause a car to bounce more over bumps.
Linear springs give a firmer ride... the car rolls less... and it doesn't bounce as much over bumps.
#57
Originally Posted by G35CDUCK
Sorry, If I sound stupid on asking this. But If all 03 G35 came with the same springs then what make the 03 6speed Coupe Sport tuned suspension different from others? And in your opion which spring offer almost the same ride as stock but give a good drop? thanks Also thanks for makeing this tread, it gives alot of info!
