Another G sedan with 350z suspension *PIX*
#182
however, when they revised the Z and G spring to the 427lb rate in 2005, the Z spring was lengthened to the same length as the G35 rear spring. Both the 2005+ Z and G35 coupe rear springs are essentially the same, so there wont be any gap difference if you go the revised route.
IMO the rear G35 coupe or revised Z rear spring looks the best and offers a more even and balanced look.
Adro (02-06-2012)
#183
Also, does anyone have any idea what the rate is on the fronts with a white dot and a green dot??? They are from a coupe and had the same revised z springs in the back.
#185
hey guys, im guessing since this thread is 13 pages long, my question has probably been answered but i cant look through all of them and i am still somewhat of a noob so id like your guys opinions:
I have a 2003.5 sedan w/ sport suspension, should i just go with 03/04 z springs for a simple 1" drop that will also help decently with cornering/handling without making it an uncomfortable ride??
All help is greatly appreciated, thanks.
#188
I have a 2006 X, and I wanted a confirmation about this...I've reading all these threads and I'm still kinda confused. I'm thinking about buying a set of 2004 Z springs (unrevised) for the front, and G coupe springs for the rear from a local member here tomorrow.
Would this setup work until I get a chance to purchase new shocks and struts? I plan on replacing the entire suspension around January, and I wanted to make sure I'll be ok till then.
EDIT: Nevermind....got the answer!
#189
#190
#191
I guess if all you want is drop, then do either. I've only used the revised springs, so I don't really have a frame of referance other than stock, but I've read on here the unrevised ones are more bouncy.
#192
https://g35driver.com/forums/brakes-...w-updates.html
Oem linear springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004 (unrevised)
Front:314 Rear:342
Hope it all works out for you!
#193
#194
Since you have the sedan sport suspension you should be able to use the "unrevised" Z springs since they have the same spring rate as your struts. See the blurb below from the following sticky that has been a big help for me and many on the forum. You may also want to consider getting the full "revised" Z suspension (springs and struts) - depending on how much you want to spend.
Oem linear springs
Front:314 Rear:342
Oem linear springs
Front:314 Rear:342
#195
