Another G sedan with 350z suspension *PIX*
Old 03-26-2008, 09:31 PM
TechFarmer's Avatar
Before and After: Coupe Wheels, 350Z front and Coupe rear Springs
Here are my before and after pictures.
First picture: stock 17" wheels, and stock sports suspensn springs
Second picture: 18" G35 coupe wheels, 350Z front springs and G35 Coupe rear springs
Attached Thumbnails Another G sedan with 350z suspension *PIX*-g35_sedan_17_wheels_stock_spring.jpg   Another G sedan with 350z suspension *PIX*-g35_sedan_18_coupe_wheels_350z_front_coupe_rear_spring.jpg
fagan59 (05-08-2019)
  #152
Old 03-27-2008, 02:07 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
^great contribution!
  #153
Old 03-27-2008, 07:09 AM
TechFarmer's Avatar
One last piece of info, here are some spring swap instructions that iI found very helpful:
http://www.350z-tech.com/zwiki/Spring_Installation
  #154
Old 04-24-2008, 07:24 PM
mariano305's Avatar
hey guys i need some help my g 35 03 has the bushing on the pass. side lower control arm is worn and i'm looking for some high performance ones but i have no luck theirs only for the 2 dr. and 350 z will they fit ????? help!!!!!!!!!!!!
  #155
Old 05-01-2008, 03:56 PM
Konsole's Avatar
Originally Posted by TechFarmer
G35x Sedan (all wheel drive):
Front: 283 spring rate
Rear: 355 spring rate
Does anyone know what the following dots are? (I have a 2006 X)
Front has one red/pink dot and one yellow dot.
Rear has one red/pink dot and two yellow dots on a different 'row' of the spring.
Is that 283/355 rates? I have seen other people mention different dots on the X and so I am wondering if they used different springs for different years.
  #156
Old 05-21-2008, 05:57 PM
ceezg35's Avatar
Where Can I Find The Stillen Sway Bars?
  #157
Old 05-22-2008, 06:55 PM
FenixL1P's Avatar
try everythingg35.com...
they have the front and rear for $299.
mines were $289 w/ free shipping back in April 2006....
  #158
Old 06-08-2008, 11:25 AM
The Gregg's Avatar
Hey guys, I have a 04 sedan with sport suspension. I was wondering if the TEIN S tech springs are compatible with the sport suspension. Also, I am still running the 17" sport wheels, would the drop from said springs be too drastic for this setup? Thanks in advance.
  #159
Old 08-14-2008, 02:53 PM
GQuerido's Avatar
clean drop!!!1
Your G looks real clean with that drop. I was thinking about putting in 350z springs for my sedan, I heard it gives an inch drop. Is this true? So you have the H techs for a 350z instead for a g? Whats the difference? Please hit me back up im new to the whole nissan thing.
Originally Posted by godmans
A side note, do you have bluebat overlay on your headlights?
  #160
Old 08-18-2008, 12:10 PM
stats's Avatar
hey guys, i have an 05 sedan with a non-sport suspension. can i order a set of 350z springs (revised or unrevised?) and not have to worry about purchasing any struts?
  #161
Old 08-19-2008, 08:33 AM
TechFarmer's Avatar
Asked and answered in this thread: the 350Z/coupe/sedan sports suspension uses higher damping rate struts. You will more bounce if you don't replace the struts, which is not a good thing.
  #162
Old 02-03-2009, 01:28 PM
blk06x's Avatar
Ugh 2 times through and I am just as confused as when I started.
Current - 06 G35x
Looking to drop around an inch all around or even up the look, its a daily driver so I do not want something too aggressive, and want close to stock ride, a bit stiffer is fine.
What setup would be my best bet? Springs and Struts or just Springs?
  #163
Old 02-07-2009, 11:01 PM
Metalhead Mike's Avatar
Current - 06 G35x
I'm in the same boat you are. Got an 06 X as well. I've been reading through this thread and dozens of others on lowering/suspension upgrades and am still confused and unsure on what exactly to get. Doesn't help that Xs are rare here, comparatively. Some posts I see say when comparing lowering values, Xs are an additional 0.25-0.5" lower than what people will list for regular sedans, sport or not. I don't think I can do a 2" drop with 18"s here, just because of the weather and the ****ty roads. Like you, I just want a 1", even drop all around, for better handling and looks, but nothing track crazy (super stiff and uncomfortable). I just need to know what to get and where to buy it.
I should stick to older cars, this **** is insanely confusing! Wiring the dash on my dad's 40 Chevy Business Coupe is/was looking easier than trying to find out stuff on lowering the G!
  #164
Old 02-08-2009, 10:35 AM
blk06x's Avatar
I am going with a set of unrevised z springs on my stock x shocks/struts I am told it will drop around an inch around, only concern is that smaller wheel well in the rear makes it look lower so some people put coupe rear springs there to drop it less.
Unrevised springs are 2 red dots 1 purple dot, and are from 04 and previous.
Hope it helps, its amazing how much info was lacking for the X
  #165
Old 02-16-2009, 03:09 AM
TycoRC's Avatar
Infiniti G35 Sedan Nismo Aero Sport Package
if any of my G sedan owners are looking for the Z setup suspension mine are forsale click on the link below
https://g35driver.com/forums/suspens...s-springs.html
Quick Reply: Another G sedan with 350z suspension *PIX*
