Another G sedan with 350z suspension *PIX*
#106
GOT MODS?
on
Originally Posted by RBull
The revised Z springs did not drop my coupe in the rear so I would say that's a waste of time to think about mix and match. In the front I got about a 1/4" drop.
Just an FYI, usually it's the sedan owners that add Z springs for a one inch drop. I don't think I have ever heard of a coupe owner adding Z springs to their car. Adding Z springs to a coupe doesn't make much sense.
Seems like most coupe owner use Tein or some other after market brand.
tD
#107
Does it have to be Z springs, can we not use coupe springs for the same drop?
tD
tD
#108
GOT MODS?
on
Yes you can put G coupe springs on a sedan but the drop is not as much. You will get about 1/2 inch vs. 1 inch or so with Z springs. Some guys go coupe springs in rear and z in front. I like the one inch drop all away around with the Z springs. Personal preference I guess.
tD
![Cool](https://g35driver.com/forums/images/smilies/cool.gif)
My car on Z springs front and rear:
![Name: Amy3.jpg
Size: 36.7 KB](https://g35driver.com/forums/attachments/brakes-suspension/224746d1501885145-another-g-sedan-350z-suspension-pix-amy3.jpg)
![Name: 100_6528.jpg
Size: 128.0 KB](https://g35driver.com/forums/attachments/brakes-suspension/224747d1501885145-another-g-sedan-350z-suspension-pix-100_6528.jpg)
#109
TAHOT (01-15-2012)
#111
Originally Posted by klg35
for us sedan guys, i think the revised oem Z suspension is perfect...1" drop all around......subtle, but very effective..
#113
[QUOTE=TunerDad]Yes you can put G coupe springs on a sedan but the drop is not as much. You will get about 1/2 inch vs. 1 inch or so with Z springs.
tD
A 1/2 inch drop in the front of my 03 sedan would be great. Is there a specific year or will any front G coupe spring work? I have had the rear springs out and that was fairly straight forward. Is replacing the front springs just as easy?
thnxs, Wayne
tD
thnxs, Wayne
#115
on
[QUOTE=Road Ruler]
If you have the sports suspension, the front springs for a z or coupe have the same rate as your stockers (all years included). It is the coupe/z rear springs that have increased rates for later years.
No, the fronts are not as easy as the rears (but they still aren't that hard). The fronts are coilovers so you will need to rent a spring compressor if you DIY.
tD
thnxs, Wayne
tD
thnxs, Wayne
#116
#117
Originally Posted by 03Sg35
is there a diffrence between the track edition z springs/struts compared to regular. Also the roadster same question, im trying to find som z springs and all I found was track edition ones. Thanx
as far as the Z goes, springs rates are the same for all models of equivalent year.
#119
Originally Posted by GTR_Boy
So if I were to put an 03 Coupe suspension (complete springs & shocks) onto an 03 Non-Sport Sedan, would the resulting drop be 0.75" front and 0.75" rear?
![Roll Eyes (Sarcastic)](https://g35driver.com/forums/images/smilies/rolleyes.gif)
