Another G sedan with 350z suspension *PIX*
Old 04-12-2006, 02:21 PM
vrsc's Avatar
Thanks
  #47
Old 04-12-2006, 03:09 PM
Mr.Igor's Avatar
anyone running Z springs and shocks with 19" rims? (235/35/19)? i would love to see some pictures of how high it would be sitting.
  #48
Old 04-12-2006, 03:12 PM
Mr.Igor's Avatar
with 1" all around i am worried, becuase the back of the car is sitting much lower then the front!
  #49
Old 04-12-2006, 03:18 PM
Foo_G's Avatar
Florida G35 Club, Premier Member
Location: Universe.Milkyway.Solarsystem.Earth.NorthAmerica.USA.FL.Tampa
I think the difference is attributed to the front fender arch being cut higher.
  #50
Old 04-12-2006, 03:26 PM
Mr.Igor's Avatar
so then i should lower the front more to make it look more even. thats why i would really like to see some pictures of 03-04 sedan on 19s with the 350z setup
  #51
Old 04-12-2006, 04:45 PM
Foo_G's Avatar
Yeah. I think that is what vrsc is looking to get info on. We spoke briefly about it over the weekend and from what I gathered it will take a combo of different springs. What I am wonder is if it looks even would the car actually be slightly jacked up and if so how so that impact roll and such.
I am hardly the consumate authority on this subject though. I am hoping to learn a little more about this subject in here and put it to use soon.
  #52
Old 04-12-2006, 05:44 PM
dyenboy's Avatar
Registered
updated spring rate data on post #30
  #53
Old 04-12-2006, 08:04 PM
SFG356MT's Avatar
Nice setup and great info. Thanks to all.
  #54
Old 04-12-2006, 11:32 PM
geeitup's Avatar
Or lower the rear less. 03-04 Z springs lower the front approx. 1 inch and the rear approx. 7/8. You can go with the revised springs, or the z/coupe combo, or a spring spacer in the back (what I did).
  #55
Old 04-13-2006, 12:48 AM
Mr.Igor's Avatar
revised springs would be even things out? by that you mean z 04.5-06 correct?
my direct question is: What EXACT setup do i need for my car to look perfect with 19" rims. 06 z front and back? Or?
  #56
Old 04-14-2006, 12:43 AM
g35guy86's Avatar
the reason i went with 03 coupe/z springs was it was an even drop and the spring rates are the same then if i went with 05 z springs it would be firmer and i didnt really want that chance of bounce.
  #57
Old 04-14-2006, 03:09 AM
Mr.Igor's Avatar
so 03-04 350z springs and struts would be the best choice for me, correct? thats exactly what you have.
  #58
Old 04-17-2006, 09:24 PM
Foo_G's Avatar
WOuld the guru's mind providing me with a little advice for my 05 with sport suspension.
I have the eibach pro on the way now but I am having second thoughts because I do not want to have to tune the entire suspesion sysem out.
What z and or coupe combo would you suggest for my car.
Thank you in advance,
-nmp
  #59
Old 04-17-2006, 10:49 PM
Foo_G's Avatar
Well i got a lead on some 03 touring springs but would really like to get some advice before I pull the trigger on the buy. many thanks!
  #60
Old 04-18-2006, 03:20 PM
vrsc's Avatar
So for my 2005 sedan Non sport suspension, I am looking to get some revised 350Z springs (z 04.5-06), shocks and struts. If I go this route it should lower my sedan 1inch evenly on all 4 corners and still give me a better (firmer) OEM ride. Is it important to which model 350Z I get these from (Touring etc.)??
Please assist with advice on this set up and Thanks for the info
Quick Reply: Another G sedan with 350z suspension *PIX*
