Another G sedan with 350z suspension *PIX*
#122
depends on when the shocks were made. if they're early 04, no; if theyre late 04 then you should be fine with the spring you chose
to be safe, i would go with 05/06 Z shocks or Tokico D-Specs to use with the 06 Z springs
Originally Posted by Jum
Do you guys know if a pair of 04 350z shocks with 06 Z Springs would be ok on my non sport sedan?
#123
man i want to do my drop already your all making me jealous .. lol
but unfortunately im going to wait for the spring time ..
all in all i guess its a good thing that i wait ..
in the time between now and spring ..
im planing on ordering:
hotchkis sway bars
gtspec:
Rear Lateral Arm Brace
Front Lower Tie Brace
Rear Tie Brace
polyurethane bushings all around
( i sure il have to get a camber kit )
with the drop il be getting from my
H&R lowered 350z springs and
d-spec shocks/struts that i just ordered ..
to have a complete suspension .
then move up to the braking ...
BUT YEAH IM STILL JEALOUS OF YOU GUYS . LOL
GREAT JOB ..
(( SUBSCRIBED ))
OH AND THANKS TO G35SEDAN FOR THE HELP .. (
hotchkis sway bars
gtspec:
Rear Tie Brace
GREAT JOB ..
(( SUBSCRIBED ))
![Biggthumpup](https://g35driver.com/forums/images/smilies/biggthumpup.gif)
#124
#126
Originally Posted by Rodrigo
after reading th thread i am considering the 03-04 350z springs for my 03.5 sedan.
I can use my stock struts ? considering they have 37k on them right?
subscribed
subscribed
#127
Originally Posted by jimmyc13
If you have the sport package, then yes, you can use them; otherwise it's wise to get some coupe shocks or struts used on this forum or my350z.com. Your non-sport ones will prematurely wear if you don't replace them due to them being compressed more.
thanks, what is the easiest way to tell if i have the sport package?
#128
We sometimes tow a trailer with our 2003 Sedan. I want to install a set of sport, or X rear spring to firm up the rear when towing. Should I also get the shocks from the sport or X donor vehicle as well? thnxs for any suggestions.
There are not a lot of G sedans in the wreckers here in Ontario Canada. Still looking though. The Infiniti dealer in town wants $400. plus tax for a set of X rear coils alone!
#129
YOU do what with your sedan? T O W ?! You mean you actually pull something with it? UHHHHHHH?
![Eek3](https://g35driver.com/forums/images/smilies/eek3.gif)
![EEK!](https://g35driver.com/forums/images/smilies/eek.gif)
![Icon43](https://g35driver.com/forums/images/smilies/icon43.gif)
![Icon09](https://g35driver.com/forums/images/smilies/icon09.gif)
![Icon16](https://g35driver.com/forums/images/smilies/icon16.gif)
#132
Originally Posted by IMAFUKINRIDER
using your g to tow something else .??
wow
wow
#135
Because of the 50 degree heatwave today I started my unrevised z spring and dspec install. I started the fronts after dinner. The shaft bolt on the strut was rusted solid to the end. Even with an impact and spraying it wouldnt come off. I ended up breaking out my cut-off wheel and cutting and then I chisel the rest off. I got the other side waiting for me in the morning lol. Hopefully ill have dropped on snow tire pics tomorrow
