Another G sedan with 350z suspension *PIX*
#256
on
^Dude, if you dropped it on Z suspension and didn't have an alignment done, it's waaay out of spec.
Getting an alignment probably won't get it 100% back in spec, but just tell them to get it as close as possible to spec and it'll be fine, a lot better than what you have now, and def not a waste of money.
#257
Here's some interesting info for people who've lowered the G with a 350z suspension.
I had a 4-wheel alignment done this morning. The alignment shop said they got everything within, or very close to, spec. Then they compared the G35 sedan specs to the 350z specs and everything was within the spec range for the 350z. I guess the 350z has more aggressive specs - presumably for better handling.
I feel much better about the swap now.
#259
I had a 4-wheel alignment done this morning. The alignment shop said they got everything within, or very close to, spec. Then they compared the G35 sedan specs to the 350z specs and everything was within the spec range for the 350z. I guess the 350z has more aggressive specs - presumably for better handling. I feel much better about the swap now.
#262
#265
#266
#269
#270
