Lowered 07 G35X and a new smile
Well my X is now lowered on the 370Z front springs and shaved rear upper seat. It is pretty well level now. It is less than an 1/8" higher in the rear but I just swapped the mounting seats today and my gas tank is at 1/4.
Overall I am really happy with the overall look and wouldn't want to be any lower due to the ground clearance of the front diff.
The car feels a lot better in the turns producing much less body roll than before. I can feels the bumps in the road a little more but nothing uncomfortable and it is to be expected anyway.
I have to say it was a pleasant experience changing the rears compared to the fronts. I did the rears in about 30 minutes. The fronts took a while. One of the spring compressors I loaned from C.T. had some tight threads and was difficult, to say the least, to turn under compression. I built up my pythons a bit so it is all good.
A big thanks to my neighbour Stephan for all his help on the fronts.
Here are a few pics.
Front left fender measured after lowered on 370Z front springs
Other pics
http://s251.beta.photobucket.com/use..._Grill_Painted
Last edited by rpm&my_G35; Jan 5, 2013 at 09:52 AM. Reason: fixed broken link to picture
Looks good Paul, didn't know you had planned on lowering it.
You know what lowering it means though....
Looks great Paul. Nice job. I didn't lower my X when i had it but know it would have looked much better. The car previous and the one now are both lowered and I love the look, and the perceived improvement in handling.
Looks good, Paul, nice improvement.
I might know where you can find some 370 springs. Just sayin'.
Good job...
so you're using the stock X spring in the back with the shaved mounts?
(I thought you had to use a RWD rear spring like from an S model)
may I also suggest you grab a front lip (OEM nismo), the difference it makes to the overall look is truly amazing.
