Hard Shift -- No Transmission fluid?
Dry, or clear that wipes off brownish red? AT fluid can kind of be hard to see on the dipstick until you wipe it off on a clean cloth. Are you sure you checked it properly with the fluid warmed up?
I didn't think I had a leak either, until one day I noticed fluid on one of my hard lines coming from the transmission and heading toward the engine. On further inspection, I noticed a pin hole leak that was in between the 2 lines where they come close to touching. Swapped them out and did a transmission drain and fill and noticed I had leaked almost a quart without knowing it.
Mad A
Not G35 Related
12-08-2015 01:45 PM
