Technical opinion needed
Old Mar 3, 2003 | 06:12 PM
Merlin's Avatar
Staff ALUMNI
Re: Technical opinion needed
Shouldn't be a problem. Probably give off the same heat temp as your other set of PIAAs and the Yellow tint may make it appear not as bright. It will come down to personal tastes I think.
<font color=blue>Merlin</font color=blue>
Old Mar 3, 2003 | 06:19 PM
Gordgee's Avatar
Administrator
It's always possible that the over wattage bulbs might cause problems. Depends if you want to take the risk or not. Always safer to run a separate wiring harness, but don't change the fuse or link to a higher rating if you don't. Also be aware of the risk in the long term about possible reflector damage from the extra heat.
<font color=green>GG</font color=green>
Old Mar 3, 2003 | 07:05 PM
Rumble's Avatar
Shouldn't be much problems, but the bulb will definitely not last as long as lower wattage bulbs in my experience.
It's still a G thang!!
Old Mar 3, 2003 | 07:27 PM
G35Coupe_CB's Avatar
Well.. it's going to draw more current. If the G wiring can handle there will be no problem at all. I have had cars that I put higher wattage bulbs with no problems.
Generally, manufacturers wiring and stuff are conservative.
going from 55W to 80W may burn a fuse. Just install higher rated fuse and hope nothing will happen.
I think you should be ok!
==Me
Vote 4 my G-FORCE
Old Mar 3, 2003 | 07:47 PM
bigel's Avatar
NO don't install a higher rated fuse! If it blows a fuse then you have your answer if its safe or not.
Old Mar 3, 2003 | 08:17 PM
IQ9's Avatar
IQ9
I agree leave the fues alone. You my not have any issues at all. I do hate getting the wrong item(s) when you orde
03.5 Sedan/B. Silver/Premium/Winter/Aero
69 Chevelle BB/4.11's
Old Mar 3, 2003 | 10:28 PM
AceIt's Avatar
kkh713x > try this website : www.hitechimportlighting.com
I order Piaa's Ion Yellow's too but they ran out but that was four months ago so they might have them in stock. So, I went with the Raybrig Hyper Yellow's. They are just as good as the Piaa's. They are the same price and they look awsome. Very similar to the Lexus foglights.
Old Mar 3, 2003 | 11:21 PM
it has nothing to do with the bulbs lasting long. They'll last as long as they should. It's just you might blow a fuse sometime.
That's all.
Vote 4 my G-FORCE
Old Mar 4, 2003 | 11:33 AM
VNT's Avatar
VNT
you'll run the risk for melting the wiring connector, melting the housing, and melting the immediate wiring itself.
Many people have put heavier duty wiring and connectors as well as adding relays to have the higher wattage bulbs perform reliably.
Hasanbaloch
Feb 29, 2024 08:45 PM
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
Ken167
Aug 7, 2015 11:12 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
