Throwing Code PO345
Old Oct 19, 2009 | 01:04 AM
Turbonegro's Avatar
Throwing Code PO345
So I have been having an issue with my 03 G-Coupe. Its been starting up with the check engine light on, but after a while, in gear, the car to stall intermitently, then jumps back into gear after a couple of seconds. Then the VDC and Slip lights came on with the CEL. After this, when the car was turned off and restarted, it would turn over for a few seconds before actually starting. But this would go away after the car sat for a little while.
Now the engine turns over for a few seconds before starting and starts up with all three lights on, even if sitting overnight.
I got the code checked, and its throwing the Cam Position Sensor P0345.
Also, in a likely related issue, my engine has been drinking oil. I added 2qts 2 weeks ago and it was dry when my mechanic looked at it the Friday.
With these combined issues, what am I looking at? From what I've read on the forum, if it wasn't for the oil issue, I would just replace the sensors. But now I'm not so sure.....
Cars mods are Z-Tube, Pop Charger, and JWT Clutch and Flywheel.
Old Oct 19, 2009 | 09:15 AM
djamps's Avatar
Hope you're under warranty. Sounds like you have an OC issue, which the only solution is a new engine.
Old Oct 19, 2009 | 11:15 AM
Turbonegro's Avatar
That's what I was thinking.....
And no, I am at close to 130,000mi. right now
Old Oct 19, 2009 | 11:29 AM
F5TG35's Avatar
man sucks your not under warranty, let me know what you find out because my other car (Z) has the OC problem!!!
Old Oct 19, 2009 | 12:33 PM
Turbonegro's Avatar
I will let you know. I am sure that I am gonna have to deal with BS on Nissan's/Infiniti's part. Not going into this with the best mindset already.....
FML!
Anyway, as a backup, does anyone know of someone who sells VQ longblocks built to not consume as much oil in TX? I would rather get a new engine than buy a new car.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
Learned Hand
Oct 1, 2015 09:02 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
