G35 & G37, Coupes & Sedans
bluetooth problem?-a solution
Old Jul 27, 2007 | 02:18 AM
pantablo's Avatar
I just wanted to share something with this group in the hopes it might help someone. I can't say it will help you or anyone but my bluetooth is working much better now.
I had issues with my voice coming over as tinny, far away and breaking up quite a bit. Frustrating to say the least. I searched here and found many with similar problems, and others with no issues. Someone that had a problem had the bluetooth unit replaced and it worked.
I took my car in [to the dealer] for this problem and they checked the unit-no problems.
They suggested that maybe the BT volume was set too high, which would cause feedback of sorts to the person on other end of call, and symptoms are similar to what I had.
Volume for BT is separate from the radio. You can set it using radio controls while talking on phone or through the setup menu. Once set it remembers the setting regardless the radio volume.
Well I tried it and it WORKS.
so, just a heads-up for a possible solution if you're having trouble with your BT...nothing to lose.
Old Jul 27, 2007 | 12:29 PM
txgcoupe's Avatar
Volume control is not an option in setup.
John
Old Jul 27, 2007 | 01:18 PM
JekyllnHyde's Avatar
^yeah, its not in the setup, but all you need to do is control it like you would with the radio volume. use the steering wheel volume control or radio **** any time when using the BT functions. the volume will show like it does for the radio. op even stated this.
Old Jul 27, 2007 | 01:35 PM
txgcoupe's Avatar
That doesn't work for me.
Still crappy sounding to the person on the other end.
Sent an email to Infiniti about the issue. Will post a response... if I ever get a reply.
John
Old Jul 28, 2007 | 03:15 AM
pantablo's Avatar
seemed to work for me pretty well.
I didnt verify in the OM if you could also change volume through the setup but believed the service guys that told me that. Its on my 07-dont know if maybe they're different than previous years in this regard. I changed it through the radio controls like stated above.
Old Jul 28, 2007 | 10:37 AM
Blue Lion's Avatar
Most of the time the person I'm talking to doesn't realize I'm using the hands-free system. Last night I talked to my wife (she was in the car) and I had no idea until I heard my son say hi at the same time she was talking.
Old Jul 29, 2007 | 03:56 PM
Petoria's Avatar
i should go try that.... everytime i use the bt i find myself screaming at the other person for them to hear me
Old Sep 10, 2007 | 02:21 AM
pantablo's Avatar
I lied. still not good BT. I'm pissed every time I use it. Going to buy a bluetooth earpiece to use in the car instead of the car BT. I might decide to fight with the service dept at SM INfiniti about it, maybe not.
Old Sep 10, 2007 | 10:33 AM
fecurtis's Avatar
Yeah same here. No one ever knows if I'm on Bluetooth or using the actual handset.
Old Sep 10, 2007 | 10:10 PM
iandi's Avatar
Mine also sounds good - 07 g35 w treo 650.
Old Sep 11, 2007 | 07:24 AM
daveblank's Avatar
Also adjust the volume of the phone itself.
Old Sep 11, 2007 | 09:04 AM
uber-mann's Avatar
Arrow Probably won't help, but...
Bluetooth spec 2.0 upgraded the original BT spec to provide two "modes" where mode 1 is original voice communication mode that emphasizes mid-range typical of human voice and is monaural. The newer mode 2 supports stereo and a flat response across all frequencies, i.e. "hi-fi". This mode is used by bluetooth wireless headphones connected to mp3 players. I do not (yet) own a G35, but there may be some setting buried on a submenu that allows you to select the alternative bt "mode." For more info research bluetooth stereo headphones.
Old Sep 11, 2007 | 11:58 AM
bocatrip's Avatar
There have been quite a few issues with the G35 bluetooth. It is far from perfected. The phone being used also plays a part in the equation. The European cars don't seem to have as many problems.
chinee
Jun 10, 2024 07:48 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Terry_G35
Aug 4, 2015 02:38 PM
mamboking
Aug 20, 2004 09:31 PM
Magpie
May 6, 2003 12:19 PM
