Passenger window problems
I have an 04 coupe and my passenger window doesn't go down 90% of the times I try for it to, but when It rarely does it sometimes does not go back up, forcing me to stay in the car for a good 20 minutes trying to bring it back up, also there are times where it doesn't Go back up and close completely like it's supposed to when I close the door. Can somebody please help me and find a solution to the problem that's only getting worse.
this thread will be the first one that pops in the searches .. i'll answer .. I was onece a noob myself
Ryanaudo you need
the window motor is bad *the brushes wear out* and it needs to be replaced .. there is a youtube video series on how to do it .. but if your not good with tools .. most mechanics should be able to knock it out within an hour or so ..
Just make sure when its reinstalled that you do the window re-learn procedure *that you will actually have to search for* ...
Good Day yall
Ryanaudo you need
Good Day yall
Ryanaudo you need
Amazon.com: Dorman 742-512 Infiniti G35 Front Passenger Side Window Lift Motor: Automotive
Good Day yall
Ryanaudo you need
Good Day yall
Micale757
Lighting
04-08-2020 10:46 AM
