Complete Clutch Flywheel Kits
Old 10-01-2015, 05:52 PM
AL8782's Avatar
I'm looking to purchase everything I need to replace my clutch & flywheel.
When searching I seen this setup mentioned my another member here. Going to get a local shop to do the work. Just want to make sure I purchase everything I need.
I was also going to get a new Slave Cylinder since for a couple years now my clutch pedal stick to the floor here and there. I actually have to pop it back up with my foot. Had the clutch fluid replaced but that didn't help and from reading the forum. It looks like this might be the problem. So I figure since I'm going to get a new clutch I might as well have them install the slave cylinder.
Nismo Clutch Disc : http://www.importpartspro.com/nicldini35g3.html
Nismo Lightweight Flywheel: http://www.importpartspro.com/niliflni35g3.html
Clutch pivot ball: http://www.importpartspro.com/niliflni35g3.html
Stainless Steel Clutch Line: http://www.importpartspro.com/ippssclli03i.html
Roller Bearing pilot bushing: http://www.importpartspro.com/nirobepibu03.html
And Slave Cylinder
Should I be good with all of these? Is there anything else I need to pickup?
Thanks
Old 10-02-2015, 09:38 PM
Jonlex99's Avatar
What no pressure plate?
Old 10-03-2015, 03:33 AM
AL8782's Avatar
Yeah I totally forgot about that.
My car only has 76,000 miles. And is very drivable even with the slipping. Just as long as I don't gun it. Do you think I would even need a flywheel?
What also thinking of maybe getting this kit
http://www.importpartspro.com/jwthdclco03i.html
Old 10-03-2015, 08:14 AM
Jonlex99's Avatar
Yes I would replace the pressure plate also...
Old 10-03-2015, 10:26 AM
Almightyone's Avatar
Smile
Might want to look into replacing the master cylinder too. They say if you replace the slave cylinder you should also replace the master. Just in case.
jsimonk
12-22-2023 03:49 PM
11bEMT
05-27-2022 03:13 PM
EPG35
08-16-2015 04:52 PM
andrewvk
Interior
08-06-2015 05:51 PM
Buggzb86
Drivetrain
07-25-2015 11:22 PM
Quick Reply: Complete Clutch Flywheel Kits
