DIY Video Series
Rating: Thread Rating: 5 votes, 5.00 average.
  #181
Old 10-09-2008, 08:46 AM
texasg's Avatar
^^^ yea me too
  #182
Old 10-26-2008, 12:40 AM
OCG35's Avatar
are the added vids throughout the thread updated in first post?
Great thead/idea btw
  #183
Old 10-26-2008, 11:56 AM
G35Papa's Avatar
Originally Posted by Infinite1
ARGH!!!! friggin rear passenger rotor won't come off!!!! Ok i'm done venting...
Any tips Eugene on getting this off? I've turned the parking brake adjustment all the way till it won't move any more w/o breaking my screwdriver.
By the way my rotors don't turn nearly as easily as it did in your video. Did I miss something? I don't have the e-brake set.
I'm sure you got this resolved by now but for others looking for answers/suggestions to this....
All you really need to do is disengage the e-brake for it to clear the rotor. The reason why it is not coming loose is because of the rust (cast iron, meet cast iron..hello rust). What I did to get mine off was spray the hub with PB Blaster (from the front and from behind) then take a long screw driver and put it inside the veins of the rotor...then wiggle back and forth. Do this on multiple sides of the rotor...it will eventually come loose.
  #184
Old 10-26-2008, 11:53 PM
bythabay's Avatar
Awesome tip Chris, much thanks!
  #185
Old 10-26-2008, 11:54 PM
bythabay's Avatar
Yes, the vids on the first page are updated every time I post a new link here. And it's that time again..
Magnefine Automatic Transmission Filter Installation
This should make a nice addition to anyone with a 5AT transmission.
  #186
Old 10-27-2008, 12:54 PM
OCG35's Avatar
cool - the only thing is I didn’t see is part # reference, or how often it should be changed... or even the benefit (is it necessary).
I don’t remember seeing any discussion about ATF filter (other then ppl asking if there is one)
Thanks for the vid though.
  #187
Old 10-27-2008, 01:03 PM
bythabay's Avatar
I believe the recommended change for these is every time you service your transmission fluid, you should replace it. Probably around every 30k or so.
Since the transmission is unfiltered (with respect to smaller particles), just like the power steering system, this filter can help reduce wear and prolong the life. The parts needed are:
Magnefine 5/16" filter (~$20 shipped from Magnefine)
Hose clamps
Automatic Transmission cooler return hose (5/16") about 1-2 feet of hose is more than enough.
You can read their faq here: http://www.magnefine.com/html/faq.html
And if you look at the bobistheoilguy forums on transmissions, you can find lots of other third party info about these being cut open, examined, etc.
  #188
Old 10-27-2008, 01:58 PM
OCG35's Avatar
^^^ great info - thanks
  #189
Old 10-28-2008, 02:40 PM
OCG35's Avatar
Anyone know of a DIY (vid or text & pics) for sedan non-reclining rear seat removal - for d-spec adjuster extension cable install?...
  #190
Old 10-29-2008, 02:53 AM
bythabay's Avatar
SPC Rear Camber Kit Install
  #191
Old 10-29-2008, 12:03 PM
G35Papa's Avatar
Good stuff Eugene
  #192
Old 11-03-2008, 09:18 PM
bythabay's Avatar
Front & Rear Coupe Splash Guards Install
  #193
Old 11-12-2008, 01:46 PM
lexusk8's Avatar
Eugene, in the sway bar end links install vid, what was the blue grease you applied on the bolt end of the sway bar link?
The install looks relatively easy, just removing 2 bolts, uninstall stock end link and reinstall new end link. I'm wondering what will negatively happen if stock end links are continued to be used with lowering springs/coilovers on our cars?
  #194
Old 11-12-2008, 01:56 PM
bythabay's Avatar
I think the blue stuff was loctite blue. Not sure about negative effects of leaving the stock ones one..
  #195
Old 12-01-2008, 07:58 PM
swede6162's Avatar
Wow, the DYI videos are great. This what is so great about being a G owner - the other G owners. Great community!
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
Quick Reply: DIY Video Series
