DIY beginning of wire tuck
#181
Received 1,939 Likes
on
#182
#183
the coupe driver side loom will not extend to fit the headlight...i have tried both the holes going into the fender. i would try the hole in the bottom because the one right behind the pump is a pain to fit through. i dont even think this is worth it after all i have been doing. what wires do we need to extend for the headlight?
#185
Gmotion: u need to take the plug on the headlight off it is hel by a clip or u can be like me n just break the clip off ether way works. Also it might still not reach after taking the plug off the clip, go back to the loom under the brake fluid tank n try o deloom more. It is worth it at end.
#191
on
#193
#194
