New g35 owner here (oil concerns)
Hi guys, I just bought a 2004 g35 with the AT transmission and I have a few questions regarding oil consumption. So before buying, I knew about some cars having huge consumption problems so I asked the seller if the car did consume oil and he said that it didn't. So when I bought the car I got it inspected at my usual garage and everything went good. The oil level was showing near H ... so this morning (drove about 250 kms during the week-end) I check it and im near the L on the dipstick. So that means I burned nearly 2 quarts of oil for driving 250 kms ... is this even possible ?
Also, I do not see any smoke coming from the tailpipe and no apparent leaks because we checked during the inspection of the vehicle.
PS. That dipstick is the worse one i've delt with so far ....
I can't take my car in because of all these horror stories (I've heard some bad stuff). I used to bring my truck in just to save time, but I've had a couple buddies work at different places that do oil/brakes/tires kind of stuff and he would tell me what some of them do and its not cool.
The worst was when he told me that if a customer was being rude they would drain their oil and then start their car with no oil in it.
If you're burning that much oil you would have heavy sticky black soot visible in your tailpipes.
If you don't have much, I'd say enigma is right. Fill 'er up and start check in for leaks. You are most likely not burning that oil.
No. My tailpipes have absolutely zero soot in them. They're just a light rust color inside. I was lucky and got one that burns almost zero oil. All cars burn a little, but the amount of soot is indicative of how much.
THanks though Ill get that checked.
