RPM Shutter after Throttle Body Clean
Hey guys. I own an 08 Infiniti G35 Sedan Base. I recently had the throttle body and intake pendulum sprayed and cleaned out when i went into service for the water pump. Once i received the car back it ran perfectly fine until i noticed when i come to a stop say a light, the rpm would idle at 6500 then drop say 500rpm for a second then pick back up. Now when this symptom happens the car does shutter for a second like the car is about the stall. I does this also if I'm sitting idle for along time it will do it once or twice in a 5min sit. It doesn't happen all the time but enough time to notice the issue. I would appreciate any advice into the issue. Thank you.
Freeman186
09-06-2023 10:07 AM
esotericrider
V36 General Tech Questions
03-04-2019 07:53 PM
