Installed weathertech visors and passenger window goes down
Check your fuse and if those are ok then you might want to disconnect/reconnect the battery and check...
Your safety window roll up is being triggered. The window thinks someone has their arm or hand in the way. Readjust the installation, otherwise there is no way to disable this safety feature unless you manually close the window vs. auto up
