LED 'em up! 56k = PC hang
LED 'em up! Lots of pics!!!!
hey guys recently finish changing my interior and exterior lights
just wanna share my pics.
All of the sizes of bulbs is found at sylvania.com
http://www.sylvania.com/ConsumerProd...lacementGuide/
Also just wanna add some other stuff
1.Vanity lights are sold from vleds.com search vanity. These light are a bit long so you need to mod the inside to fit. Its not visible so its ok.
2.Glove box light- 74 wedge bulb
The way to take this out is to unscrew the 4 screw in front then pull down the plastic panel. You'll see a white square plastic housing just twist it and you'll get to the 74 wedge bulb
^^^^Just pull to remove the bulb
How to Remove the bulb on the glove box and the bulb on the top compartment(if you DO NOT HAVE Nav)
Useful Information:
Q:
A:
If you guys want the same or better Exterior lights. Send a PM to the guy below
The bulbs are made in Japan
Heres some pics:
exterior:
City Lights: 6k 158 bulbs----Lights from jay.Diem
***This are NOT FOG lights!!! Infiniti calls it city lights or park lights
Plates: 13k 158 bulbs (old ones) ----Lights from jay.Diem
New Set 1 watt bulbs ----Lights from jay.Diem
***note: as you can see the parking lot has lights. If there is none the LEDs is much more brighter also the plate light mounting on my chargespeed bumper is different from stock. The stock has better placement and as you guys can see even the inside of the bumper is lit! lol! Thats how bright this is
Interior:
Doors:
Maplights: 9 LED smt
Upper storage box: 158 wedge bulb -- 4 LED
Glove box: 74 single LED wedge bulb
Vanity lights: 3 LED festoon bulb
Trunk: 158 4 LED wedge bulb: * if you guys can get brighter ones the better!
Hey, check this out. Watch the video. When they take off the glove compartment at 3:17 he disconnects a lil' wire, that's the small 74 bulb that should be replaced.
http://www.infinitihelp.com/diy/gsed...dure_video.htm
The bulb can be purchased here:
http://v-leds.com/24-74-LED/White-LE...orLanding/true
If you want to replaced the bulb on the upper glove box, you should reach behind it after removing the glove box and feel for a wire around where the bulb should be. If you look at the bulb in the upper glove box, you'll get an idea of where to feel around in the back for the wire. When you find it, it's locked in much like the bulbs in our clear corners. Simply twist and pull it out. The bulb is a 194/168/158 bulb and can be purchased here:
http://v-leds.com/194-168-158-LED/Wh...orLanding/true
Have fun!
Have fun!
Useful Information:
Q:
A:
Please PM Jay.Diem <-Click the name to send a MESSAGE
Heres some pics:
exterior:
Interior:
Doors:
Originally Posted by ShanesG
those are bright as fvck! They don't look luke v-led lights mine are def not that bright and I bought the brightest ones they had or so I thought! Are they all vleds?
yeah the exterior ones are not VLEDs i got em from jay.diem cost a pretty penny too but i think it looks great. fronts are 6k(white) plates are 13k(white w/ hint of blue) interiors are VLEDs
The vanity is hella bright though
Originally Posted by dranom
i posted his profile for you guys. check the top of the page
dranom - Thanks though really want to do this.
