rearview mirror rattle (FIXED)
Old Apr 22, 2005 | 11:16 AM
Wanchu83's Avatar
well, I had the problem with rear view mirror inside of car, and it rattled whenever I went over the rough road.
The botton cover trim(piece that is toward you)were not tightly bonded with the other part, so it made some rattle.
I took dealership to retorque my rear axle and mentioned it with it..
AND they replace with new mirror!! yeah~
I was suprised they did that^^
and after I retorque rear axle, the car feels more right..um, no clicking noise and when it shift, it shift more smoothly.
If you have rattle problem like I did, take it to the dealer and tell them
Old Apr 22, 2005 | 11:30 AM
WhiteMikeG35's Avatar
wait im confused, you are talking about two seperate things here right? What about this rear axle re-torquing? What were the symptoms that made you believe you had something wrong there? Because my car "clicks" when I shift the weight of it (ie. when i go into gear and weight transfers back or hit the brakes and weight transfers fwd) Also, my shifting has been getting "notchy" not smooth. Maybe I need this rear axle work done?tell more about it please!!!
Old Apr 22, 2005 | 02:35 PM
madchef's Avatar
rearview mirror rattle(REMOVED+REPLACED)
Old Apr 22, 2005 | 02:41 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
I fixed the mirror rattle myself by taking the two halves of the mirror apart and lining the margins with thin foam tape. I don't trust those mechanics at the dealer to fix rattles ever since they stripped a few bolt threads on my driver door trying to fix the window rattle.
Old Apr 22, 2005 | 08:12 PM
shooter's Avatar
It's not the critic......
I snapped a few pics of my attempt at quieting the noisy mirror
first one shows the mirror in 3 pieces.....i used a small screw driver to separated the 2 halves.....be careful the plastic is soft and will mark....the front half (the half with the buttons) snaps into the back half, there are many little tabs that can be pushed down as you separate the 2 halves
the second pic shows the front half and back side of the buttons....i spread the silicone on the bottom of each button.....spreading it into the recesses of the buttons and let it dry......
the third pic shows all the little plastic posts that support the mirror and card (there must be 25+ posts) ...i put a dab of silicone on each post and let it dry.........not too much, just a little dab...there are 2 posts that insert into the card.....too much silicone will make it harder to push back together (the q-tip in the pic is right over 1 of the posts)
snapped it back together and it sure made a big difference! no more mirror rattles!
Attached Thumbnails rearview mirror rattle (FIXED)-dsc02215.jpg   rearview mirror rattle (FIXED)-dsc02219.jpg   rearview mirror rattle (FIXED)-dsc02220.jpg
Old Sep 20, 2005 | 11:22 PM
tdotG's Avatar
Thank you Shooter!! The rearview mirror rattle has been bugging me to no end for 2 years. Two different dealers I brought it to were not able to fix it. In fact the last dealer I went to charged me to try and fix it. The service advisor explained that it has passed the one year new car period and even TSBs are charged labour unless it is a recall. I paid them, they put a little felt on the plastic piece per the TSB and of course the rattle was there when I drove off the lot.
The most irritating thing was that if I just put a finger on the rearview mirror, the rattle would go away. It was so annoying that I almost ripped the mirror off the windshield numerous times while I was driving. Finally, this past weekend, I took my rearview mirror apart and with your great pics, have fixed the problem.
Now if I can only fix the streaking on the passenger window...
Old Sep 20, 2005 | 11:57 PM
andychan's Avatar
[QUOTE=tdotG]Thank you Shooter!! The rearview mirror rattle has been bugging me to no end for 2 years. Two different dealers I brought it to were not able to fix it. In fact the last dealer I went to charged me to try and fix it. The service advisor explained that it has passed the one year new car period and even TSBs are charged labour unless it is a recall. I paid them, they put a little felt on the plastic piece per the TSB and of course the rattle was there when I drove off the lot.
Correct me if I'm wrong, but isn't the mirror rattling fix covered under warranty? 4 year 60K miles. I think you shouldn't have to pay them for that.
Old Sep 21, 2005 | 08:31 AM
ericsherbrooke's Avatar
the pics you have posted are all mess up (probably because the site update)
Is there a way for me to see them?
Old Sep 21, 2005 | 08:43 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I'm doing the same fix this week...
It seems to be inherent to the design....
so if it's replaced, it'll more than likely just come back.
Might as well fix it myself & be done with it.
Old Sep 21, 2005 | 02:02 PM
adawar's Avatar
Shooter: thanks for the tip, I actually tried this but couldn't get the two halves apart... can you repost your pics?
Annu
Old Sep 21, 2005 | 03:37 PM
tripwire's Avatar
What brand of silicone and what store did you get the silicone, may I ask? The rearview mirror rattle has been bugging me as well, and taking it for a dealership fix is a such a dice-roll with Infiniti
Old Sep 21, 2005 | 03:47 PM
InTgr8r's Avatar
Don't think it matters.
Any general pupose silicone will do. (it's hidden inside when done)
Old Sep 21, 2005 | 03:53 PM
B33R's Avatar
I've had my rear view mirror replaced 2 times for rattles. I am now very good at re-programming it
Old Sep 21, 2005 | 03:57 PM
InTgr8r's Avatar
That's what I thought would happen.
Might as well fix it myself instead of replacing it several times.
Who ever supplied these things to Nissan must be getting an earfull by now.
Old Sep 21, 2005 | 08:10 PM
InTgr8r's Avatar
Just found a quick fix.
I had an idea that I thought I'd try B4 taking the mirror apart.
I cut some thin plastic strips...
You know, that heavy molded clear plastic packaging that parts are shipped in.
The stuff you curse when you get back from the store,
because you can't get it open w/o a box cutter.....
Anyway I cut 4 strips ~ 1/4" by 3" ;
(didn't measure, should be narrow enough to be hidden)
I stuffed them between the mirror glass & the frame (@ the front).
2 in the top & 2 in the bottom.
Took more time to find some plastic & the box cutter than it did to fix.
Went for a test spin down a road that always causes the buzzy vibration.....GONE
