TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Radio and Climate Control Electrical Problems???
Old 12-29-2010, 04:56 PM
Black2003G35's Avatar
Angry Radio and Climate Control Electrical Problems???
Hey Everyone...I have a 2003 G35 Sedan and for the last year the radio and climate controls have been acting weird. The climate controls will raise to full fan and the temp will raise to 85 degrees without me touching anything. When this happens I won't be able to do anything with the radio controls either.
I won't be able to turn the radio off, turn the channel or lower the volume that raises on its own.
Has anyone else experienced this?
The auto body place I took it to today printed me out that there was/is an audio finisher circuit board voluntary service campaign and that your dealer will change this and that should fix the problem.
My dealer did it back in Feb 2010 and charged me and it is still screwed up.
Any help or guidance would be appreciated.
Thanks.
Old 12-30-2010, 01:40 AM
anmblackG's Avatar
That is notorious in the 1st gen g35. This issue has been covered on this forum several times by several members here. Try the search button. Most of us had upgraded the head unit and went with a dual din finisher and a new ac controller. Imho it's worth it. You might find a used hu/ac here on the classified or ebay, but may not last. The labor to swap out yours won't be cheap. Go to a reputable car audio shop that's familiar with G35s. Good luck.
Old 06-18-2013, 10:52 AM
ssulik's Avatar
G35 Audio Finisher Circuit Board Recall
I've been told the Infiniti Recall/Notification for the Audio Finisher Circuit Board is IPV03-007, but cannot find an authoritative source to show the dealer. Can anyone help ?
Old 03-04-2014, 03:32 AM
The Pawnfather's Avatar
Its probably the Audio board. In all honesty I would bite the bullet, and spend the coin to put a aftermarket radio in. Spending the money sux,but a wise man once told me "If you go cheap you'll cry every time, but If you go expensive you only cry once". Good luck
WillisFL
12-29-2016 08:56 AM
derres
08-28-2015 03:27 PM
Tyler's03G
08-13-2015 10:04 AM
Danielek
08-11-2015 09:33 AM
kd03g99
07-30-2015 11:24 AM
Quick Reply: Radio and Climate Control Electrical Problems???
