Low tire pressure warning light
Old 08-21-2014, 10:19 AM
Jeemeez's Avatar
I have a 2005 G35X I bought used that has 104,000 miles. The Low Tire Pressure Light is giving me fits. It is off when I start the car then comes on and stays on after about 10 minutes of driving. Speed does not affect this. I had the TPMS's checked and they are okay. I also had a tech check the car with an OBD meter when it was running and the light was on and it gave me a C1724 code. The car did have an electrical problem due to bad wiring of an aftermarket stereo. That stereo is now out and the OEM Infiniti stereo is back in place. So after all this, anyone else have the same problem with the warning light?
Old 08-21-2014, 10:33 AM
Spartan268's Avatar
Apparently C1724 means one of the transmitters are done. If you google and click the first link you'll see.
Jeemeez (08-21-2014)
gary c's Avatar
Received 1,132 Likes on 1,002 Posts
I have a bad sensor in one of my wheels, it takes about 40 miles at freeway speed for the light to show up on my dash. Since there is no noise when it shows up I know what it is, I'll replace it when I need new tires with a complete new Nissan set...Gary
Old 08-21-2014, 11:36 AM
Jeemeez's Avatar
Thanks Spartan. I have had the TPMS's checked and reset twice. Still have the problem with the warning light
Old 08-22-2014, 11:13 PM
GuyLegend's Avatar
I have the same issue. Will always come on after about 30 min but shuts off when restarting the car. All the sensors checked out - but the dealer didn't read the code with the light on.
Old 09-15-2014, 05:54 PM
bigwass42's Avatar
I have a similar problem. my light comes on maybe once or twice a month and then suddenly this morning came on with a long beep followed by another long beep. since it never beeped before i checked the tire pressure and they were all ok. it stayed on for my 20 minute ride to work. stayed on my entire ride home from work 8 hours later and went off 2 minutes before i got home.
It was way colder this morning then it has been all year, could that have anything to do with it? and does anyone know what the beep and light means instead of just a light? thanks for your help guys.
Old 09-16-2014, 09:53 AM
Mustang5L5's Avatar
These sensors only last about 6 years.
With the influx of TPMS threads popping up, I would venture to guess that there are a lot of sensors out there that are finally giving up the ghost.
Urbanengineer (09-16-2014)
Old 09-16-2014, 12:09 PM
Urbanengineer's Avatar
Received 1,018 Likes on 936 Posts
Check eBay for a $90 deal on four... That price cannot be beat.
Old 09-16-2014, 12:28 PM
gary c's Avatar
The independent Nissan shop that does my alignment (the only one that gets it right) recommends using only Nissan sensors due to the superior quality. I'd much rather get it right the first time than buy sensors from eBay and have to repeat the install a year from now. My wheel sensors have lasted 10 years and have been in and out of 5 sets of wheels, I'll stay with Nissan...Gary
Old 09-16-2014, 01:55 PM
They are 40700 CD001 sensors. Apologies. Four for $90.
Old 09-18-2014, 06:08 PM
bigwass42's Avatar
Yeah I saw those on eBay also, that seems way cheap, does anyone know the quality on generics? I'm probably just going to replace them when I replace my tires in a month or two. The warning light is off, for now...
Old 09-18-2014, 09:09 PM
They are oem!!!!!!!!!!!!!!!
Old 10-22-2014, 06:04 PM
skippyG's Avatar
My 2005 does the same thing... Takes about an hour though @ highway speeds. No beep & tire pressures were within .5 psi of each other. Resets itself after cycling the ignition.
ghost_g35
08-07-2015 10:31 AM
joedaddy1
07-28-2015 02:58 PM
Quick Reply: Low tire pressure warning light
