GREAT condition OEM 07-08 G35S Sedan wheels. I have General G-Max AS-03 tires mounted on them at the moment. Rears need to be replaced, camber wear is obvious. Front tires have good tread.
2nd Gen 2007-2008 18" G35S Sedan OEM Wheel Specs
Front: 18x7.5 +45mm offset (appx 23.7lbs)
Rear: 18x8.5 +50mm offset (appx 22.4lbs)
I'm certainly willing to remove tires and selling wheels alone. If buyer wants TPMS, add $50.
Tires are General GMAX AS-03. Rears need to be replaced, fronts I will measure but have plenty of tread.
Quote:
IF these will fit a 2007X with no sensor troubles, I am interested.Originally Posted by FIFE
I understand that the V36 AWD Sedan runs the same 7.5" wheel at all 4 corners. However, from what I've seen, others have successfully run the staggered setup on their G35X by keeping the overall diameter of all 4 wheels as close to OEM as possible, which looks to be 26.9-27" for each tire.
I ran 225/50/18 and 255/45/18 General G-Max AS-03 which are still mounted and they were 26.9" diameter on fronts and 27" on rear, so the rolling diameter on your car would work with those tire specs.
Please do some research to ensure you feel confident installing these on the G35X as I'm selling the wheels with the agreement that I'm not responsible for any malfunction of your AWD system.
With that said, the TPMS sensors will work once you get them activated to your car.
Let me know what you decide!
I understand that the V36 AWD Sedan runs the same 7.5" wheel at all 4 corners. However, from what I've seen, others have successfully run the staggered setup on their G35X by keeping the overall diameter of all 4 wheels as close to OEM as possible, which looks to be 26.9-27" for each tire. I ran 225/50/18 and 255/45/18 General G-Max AS-03 which are still mounted and they were 26.9" diameter on fronts and 27" on rear, so the rolling diameter on your car would work with those tire specs.
I have an X with this exact same setup but my front tires are 225/50/18 and rear 245/45./18 and there is no issues impacting the AWD system. The only issue is it tears through tires since you cannot rotate tires. My current tires got only 24k on them and I have to replace them now (fronts only and I had a slight alignment issue). But on my X model I decided to get all the same so I can rotate. I will be selling the same rims soon that are powder coated graphite.
How much for just the wheels and sensors shipped to 02478? i have no clue how much it costs to ship wheels. How old are the sensors?
No bite, these are still for sale. I'm about to remove the tires and sell the wheels + TPMS only.
