FS[NorCal]: Vossen 084 20x9 +32 20x10.5 +42
SOLD: Vossen 084 20x9 +32 20x10.5 +42
Wheels are SOLD
For sale is a set of used Vossen VVS 084 wheels. The wheels DO NOT include tpms, valve stems or tires. They do include lug nuts and a locking nut, as well as the keys to the lugs. Wheels are located in Elk Grove CA, just outside of Sacramento. I am asking for $1000 + shipping. Please contact me if you have any questions.
Wheel specs
20x9 +32 offset
20x10 +42 offset
The wheels are marked as being made for a 112x5 fitment, but they were drilled out by vossen to fit 114.3x5 fitment. I've had these on my G since February 2009. Link to thread and have not had any issues with stability/vibration of the wheels or tire leaks. The only issue I have is a cosmetic issue. One of the rear wheels clear coat is peeling up in a couple of areas, all the other wheels are fine.
Condition
Wheels are in used condition, and will have some light scratches and minor scuffs on the lip and center when viewed up close. This is from cleaning the wheels, which is nearly impossible to avoid. Also, everyday normal wear on wheels from debris on the road, pebbles etc. The lug areas will have some minor scuffs as well from taking them off and putting them back on. I have captured as best I could any noticeable scuff/scratches, and dings in the pics below. Again, these are used wheels, they will not be perfect. None of the wheels are bent, have cracks, or have any curb rash. One of the pics below makes it look like there is something wrong with the center cap, its just the reflection from a tree in my yard.
Blemishes
This is the rear wheel with the clear coat issue. Last pic is of a small dimple, probably from a small rock on the road.
Below are pics of two small scuffs the first one was from the right front wheel, the second from the left front wheel.
Last pic is the lug type that will be included.
Wheel specs
20x9 +32 offset
20x10 +42 offset
Condition
Blemishes
I am not 100% certain. I did a search on google, and there is a guy running vossen 084's on this is250 with +38 on the front and +45 on the rear. I am assuming it wouldn't be an issue for the rear since there is only a 2mm difference in offset. Not sure about the fronts since there is a 6mm difference.
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
