FS[SoCal]: 20" Work VS-XX Silver
Old 06-24-2011, 09:51 PM
eurodre's Avatar
running the 20mm spacers will clear bbk anyways regardless of the pad
Old 06-25-2011, 01:23 AM
bdeitemeyer's Avatar
I wouldn't be interested in running adapters, I'd get them re-drilled to 5x114.3.
Thanks anyways.
Old 06-25-2011, 10:31 PM
Realtor's Avatar
Pictures
Anyway you can post pictures of the rear wheels and side views on the car?
Will I need to roll my fenders in the back to clear the wheels?
thanks.
Old 06-26-2011, 12:10 AM
jlau's Avatar
thanks.
http://www.flickr.com/photos/2048024...n/photostream/
um the rear pictures on on the post. and yes will need a fenders roll
Old 06-26-2011, 11:10 PM
jlau's Avatar
bump
Old 06-27-2011, 09:35 AM
dopetime's Avatar
didn't you post these a few weeks ago as well?? but it really sucks that they're not 5x114.3!
you're positive that they're clear bbk even though you don't know the disk?
Old 06-27-2011, 10:23 AM
He-man's Avatar
according to wheels spec listed, here are the answer:
fronts are A disk plus 20mmm adapters should clear bbk
rears are 0 disk plus 20mm adapers should clear bbk
Old 06-27-2011, 10:27 AM
qwerty0092's Avatar
how do you know that there A, O Disk??
and what about without the adapters??
Old 06-27-2011, 10:34 AM
eurodre's Avatar
because that's the only remaining disks to even consider
the r disk WILL clear, so the left over ones are A and O and thus A and O disk will clear bbk with a 20mm spacer, common sense
Old 06-27-2011, 11:09 PM
qwerty0092's Avatar
....anythings gonna clear with a 20mm. i'm asking without.
Old 06-27-2011, 11:29 PM
eurodre's Avatar
o disk will not and A disk MIGHT
you can always call up work wheels usa at (714) 968-7040 to confirm but most likely they will will ask you the specs of your caliper in order to give you the most accurate information
however further searching led me to this
http://www.workwheelsusa.com/media/w...-XX%20Spec.pdf
by the looks of it the 9.5 +18 is an A disk and the 10.5 +13 is an O disk, confirmed by the same offsets and lip size
Old 06-27-2011, 11:57 PM
qwerty0092's Avatar
^^^damn thats one sick chart!
guess bbk guys are going to have to run some adapters anyways to clear so i guess there's no need to redrill!
Old 06-28-2011, 12:01 AM
eurodre's Avatar
yeah that's honestly the best option because either way you go unless you order ONLY r disks you will need to run some kind of spacer and at least with this adapater you will clear bbk AND sit flush so you win more than once
Old 06-28-2011, 07:20 PM
jlau's Avatar
SOLD SOLD SOLD SOLD ! Thanks everyone !
DimQ
08-14-2015 02:04 AM
julian.dion
07-29-2015 09:16 AM
Kal Hamm
07-24-2015 08:55 AM
realtalk21
07-20-2015 09:07 AM
Quick Reply: FS[SoCal]: 20" Work VS-XX Silver
