Forged Performance: Electronics Summer Closeout
Old Aug 29, 2011 | 05:59 PM
Zach@Forged's Avatar
Attention G35driver Community!
We have quite a few interior eletectronics just sitting on our shelves ready to be shipped! This means these will be shipped out the same day they are ordered with no waiting period!
Escort Passport 9500ci:
The PASSPORT 9500ci is the ultimate custom-installed radar and laser defense system. With blistering all-band radar protection and precise laser "shifting" technology, speeding tickets can be a thing of the past. ESCORT continues to lead the industry by incorporating its patented GPS technology that automatically identifies the source and location of all radar signals. Real threats are processed in less than a second, while false signals are learned and eliminated. Now all you have to do is drive!
The PASSPORT 9500ci is completely undetectable to all radar detector detectors, keeping you unseen and unnoticed. Crystal-Clear Voice Alerts, Speed Alert™, Safety Warning System and its stealth installation make the PASSPORT 9500ci the ultimate in discreet protection. The all-new PASSPORT 9500ci is the Mack-Daddy of all radar and laser detectors. For those who only want the best in their vehicle. It is the ultimate balance of long-range performance, intelligent signal processing, simple intuitive controls, and the best overall driving experience ever developed. And, it's an ESCORT.
Traqmate Complete GPS Data Acquisition System:
This complete track-ready setup includes everything in Traqmate Basic plus an ergonomically designed display unit that will show your laptimes in your car including lap comparison and best lap icons. You can choose drivers, cars, and tracks, erase unwanted sessions, and get immediate feedback on the performance of you and your car on the backlit, bit-mapped graphic display. Qualifying mode adds in a predictive laptimer that shows you how fast or slow you are compared to your best lap.
Kit Includes:
  • Traqmate GPS Sensor Unit
  • Traqmate Display Unit w/ backlight
  • Traqview Analysis Software for Windows TM
  • Magnetic mount GPS antenna
  • Velcro mounting
  • USB cable
  • 6' Locking Connection Cable SU - DU (M - F)
  • Cigarette lighter or 12VDC Power Cable
Defi Control Unit II:
Defi-Link Control Unit II is a necessary controller to install Defi-Link Meters, Defi-Link Meter BFs, and Defi-Link Displays. Up to 7 gauges and displays can be connected and controlled by one Control Unit II. The name of the connection system is "Defi-Link System."
  • Driving data can be stored and can be replayed up to 3 minutes(*1). Pause, speed play, forward, and rewind function can be applied during playback.
  • Double Warning function by a meter’s LED lamp and a beep(*2)
  • The switch panel is embossed and buzzer sounds by pushing the buttons.
  • The characters and the rings on the switch panel are illuminated in white at nighttime. It makes operation in the dark easy.
  • Defi-Link Indicator(sold separately) can be connected to M-WARNING connector. The indicator blinks when any of connected meters’ warning LED lights.
  • Differential pressure between fuel pressure and turbo can be shown if both of fuel pressure meter and turbo meter are installed.(*3)
  • UP to 7 gauges among from Defi-Link Meters and Defi-Link Meter BFs and Defi-Link Displays can be operated with one Control Unit II. Microcomputers are equipped with meters and Control Unit II. A distant meter can be operated at hand.
Defi Advanced Control Unit:
Defi-Link ADVANCE SYSTEM is the next generation system that adopted the interactive communication. This is necessary to operate ADVANCE CR, ADVANCE BF and ADVANCE ZD.
  • Interactive communication advanced system is implemented.
  • ADVANCE Control Unit can control up to 7 Defi-Link Meter ADVANCE CRs and ADVANCE BFs all in at a time. (Ex. 4 ADVANCE CRs and 3 ADVANCE BFs)
  • Gauges can be controlled from distance with the included switch unit.
  • Opening and closing modes can be selected from 2 variations.
  • The installation of additional gauges is easy. Just connect it with the other two gauges and attach the wire to Advance Control Unit.
  • Power source indicator (blue LED) assures correct wiring.
  • Warning by buzzer sound when the warning LED is on (buzzer sound can be turned on / off).
  • Peak value and warning value during driving are stored. Driving data can be stored and replayed up to 3 minutes.
  • With both fuel pressure gauge and turbo installed, differential pressure can be monitored on the fuel pressure gauge screen.
  • ADVANCE Control Unit is threadably mountable.
Defi Gauges:
The gauges that we have on the shelf are as follows:
  • Defi Boost Gauge #DF06503
  • Defi Fuel Pressure Gauge #DF04502
  • Defi Turbo 2.0 Gauge #DF09902
  • Defi Oil Temp Gauge #DF10402
  • Defi Oil Pressure Gauge #DF10202
HKS Turbo Timer Type-1:
The Turbo Timer Type-1 features a light blue LCD backlit display and has the same basic timing and voltage features as the Type-0 plus several monitoring and measurement functions. The Turbo Timer Type-1 features an Auto mode for the timer function allowing the Turbo Timer to automatically calculate optimum idling time according to the most recent driving pattern. Vehicle speed and RPM can be displayed on the Type-1's LCD monitor and a speed warning level can be set. A two-stage RPM warning can also be set and used as a shift indicator. When a warning level is reached the Type-1's LCD monitor will blink and an audible beep will sound. The HKS Turbo Timer Type-1 also features various measurement functions including 1/4 mile timer, 0-60 timer and a stopwatch function that can be used for lap timing. The Turbo-Timer Type-1 can read in either MPH/SAE or KPH/Metric.
HKS Electronic Valve Controller:
The new HKS EVC has improved boost stability for maintaining pressure at high RPMs providing increased top-end power, and a new mapping feature allows boost pressure to be precisely tuned for throttle + RPM (or vehicle speed). The new EVC also offers a selectable kPa or PSI unit of measure, and a unique warning feature where if over boosting occurs, boost pressure can be programmed to drop to a user preset level. The new target boost setting and volume **** with three button user interface makes setup and tuning intuitive and simple. The design of the new EVC features a sleek black case with a clear acrylic faceplate and a positive lit LCD display offering a sophisticated look.
AEM MAP Sensor Kit 3.5 Bar:
3.5 BAR / 50 PSIa MAP Stainless Steel Sensor Kit. Stainless Steel Sensor Body. 1/8" NPT Male Thread. Includes: 3.5 BAR / 50 PSIa Stainless Steel Sensor, 12" Flying Lead Connector, 1/8" NPT to -4 Adapter & 1/8" NPT to 3/16" Barb Adapter.
All AEM Sensors include a flying lead with a weather-tight seal and 12 inch insulated wires that are color coded in black, green and red! This is important since the correct connector will give you the most accurate voltage possible.
Call, email or PM one of the always friendly representatives at Forged Performance today for pricing.
770-792-0202
Old Aug 31, 2011 | 03:00 PM
Who want's a great deal on these products shipped same day?
Old Aug 31, 2011 | 11:49 PM
LowNSlowG's Avatar
do you have any defi bf gauges laying around that you never sold?
if so pm me what you have thanks
Old Sep 1, 2011 | 09:16 AM
PM sent!
Old Sep 22, 2011 | 12:16 PM
These electronics are still on my shelves! I need to find these parts some new homes, so i'm letting them go for an outrageously low price!
Old Sep 28, 2011 | 01:29 AM
jkwinner12's Avatar
Escort Passport 9500ci shipped to 11776
Old Sep 28, 2011 | 09:15 AM
PM Sent!
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Tmatheso
Dec 13, 2015 03:24 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
