Parrot Bluetooth Products
Old 02-22-2006, 05:03 PM
EverythingG35's Avatar
We are proud to now carry Parrot Bluetooth kits. We have the CK3100 & the all new CK3200 (with color LCD) in stock and ready to ship! You can check them out on our site:
Parrot CK3100
Parrot CK3200
If you have any questions on them feel free to ask! We've installed them on a few cars here and so far everyone has loved them.
Old 02-27-2006, 07:58 PM
NETSHARK's Avatar
they are direct plug n play or they need to purchase an additional harness ?
am gonna order a AAI-NIS2 so it will be ok to install Parrot Kit after AAI-NIS2 is on ? or there will be some problems ?
Old 02-27-2006, 08:02 PM
Texasscout's Avatar
Received 2,116 Likes on 1,768 Posts
That's about $5.00 cheaper than most I've seen. The only problem I have with Bluetooth is that you still have to put an antenna on if you want good reception and you still need a cradle for that if you don't want a wire showing with your phone plugged in.
Old 02-27-2006, 08:05 PM
luongdmd's Avatar
interesting...
Old 02-28-2006, 02:06 AM
GeeMan's Avatar
You've said this before. I don't understand what you mean. Bluetooth connectivity between devices has nothing to do with antennas. Are you saying your phone needs an external antenna to get good CELLULAR reception? Bluetooth devices communicate up to 30 feet from each other (in theory) without the need for any external device. You don't see a Bluetooth mouse with a little aerial attached.
Old 02-28-2006, 08:05 AM
Texasscout's Avatar
That's exactly what I'm saying. I live in an area that has few towers in some places. (Outside sales) I am all over the place. It's not uncommon for me to be 30 miles from a tower. You MUST have an external antenna to get reception in those areas. In my old company car I had an "install kit" that had a cradle for the phone that had an external connection for the antenna. With a good "hard wired" antenna (not a thru the glass), I hardly ever had a dropped call.
Old 02-28-2006, 05:08 PM
GeeMan's Avatar
Okay. I was confused by your wording. It's not the Parrot system you're faulting but the lack of a Bluetooth phone with external antenna connection possibilities. Got it.
Old 02-28-2006, 05:19 PM
Dark Genesis's Avatar
Over here at Fry's Electronics (Yes, I'm a Fry's Electronics employee ), we are also selling the Parrot CK3100 except it's going for $199.99, installation requires alot of custom drilling. for the microphone and the controller. It does not have an external antenna or anything. It's similar to the stock bose headunit that comes with bluetooth on the 06' without the bluetooth antenna.
Old 03-12-2006, 01:45 PM
SDGuy's Avatar
Originally Posted by NETSHARK
they are direct plug n play or they need to purchase an additional harness?
The Parrot is not plug and play with Infiniti Bose. We do make an interface. You can read some of the background at http://members.***.net/quickconnect
Howard
Old 03-12-2006, 04:53 PM
ttrank's Avatar
Grocery getter
Do you need to have anything else besides a bluetooth phone to make this work?
Old 03-12-2006, 09:09 PM
SDGuy's Avatar
Once your kit is installed in your G35, the bluetooth phone stays in your pocket or purse. It links with the kit when you start your car (takes about 25 seconds). In the case of my Verizon (Motorola) E815 phone, it does everything - shows signal strenth and battery level on the display, rings and mutes the radio when a call comes in, shows called ID, and the full voice capabilities on the phone are available by just pushing the green button. You can say "Call Fred" or you can say "Call 555-555-1212". It is very cool. My wife and I both have bluetooth phones and it stores her info as well as mine (up to 5 phones) so it knows who is in the car. When I start the car, it downloads any changes to my phonebook automatically. Parrot does bluetooth right IMO. Highly recommended.
Old 03-12-2006, 11:36 PM
ttrank's Avatar
Grocery getter
That sounds really nice. But do you have to install anything besides this kit and have a bluetooth phone? My car is an 04' and does not have the factory bluetooth so I would like to make sure first.
Old 03-14-2006, 01:35 AM
SDGuy's Avatar
That is all. The Parrot unit (with our harness for a no-cut install) + a bluetooth phone and you will be set. That is the point of the Parrot - to retrofit your car to have handsfree. In fact, if you listen to the guys with the Maximas and FX's who got factory bluetooth in their '06, they don't have half the features of the Parrot...
Old 03-14-2006, 02:20 AM
ttrank's Avatar
Grocery getter
Sounds great I will be getting one.
Thanks for your help!
Old 03-16-2006, 02:29 AM
BadCommand's Avatar
yep- have an 06 g with built in BT and am replacing with the Parrot 3200 due to the Parrot having far more critical/essential features.
Quick Reply: Parrot Bluetooth Products
