UT crank pulley
Old Aug 29, 2007 | 01:12 PM
gunmetalg35's Avatar
SHADYVILLE.BIZ
Arrow UT crank pulley
$90
"How do Unorthodox Racing pulleys give me more power?"
Weight loss is the most critical factor in making, or more accurately, relesing Horsepower! Each pound of weight taken off the engines rotating assembly is worth approximately 2.7HP and the figure increases dramatically with forced induction, nitrous, VTEC and increased RPM's. Only 15-20% of the gains seen from our pulleys comes from the underdriving. The diameter of each of our crank pulleys is reduced up to 20%. We tailor the exact amount of underdrive to each vehicle based on factory specified accessory performance. We fully maintain all accessory output minimums like air conditioning efficiency, power steering feel, and voltage (minimum allowable voltage 12v) even at idle with everything electrical on in the car. There are no adverse effects from using any of our pulley versions. Bolt them on and forget about them, then just follow your vehicles normal maintenance schedule.
Old Aug 29, 2007 | 02:01 PM
App6MT's Avatar
Littering and...
PM Sent.
Old Aug 30, 2007 | 12:45 AM
rwcblkcoupe's Avatar
Curious
1st:
this looks like an ad. To witch you should be a Sponsor of the site and or post this in the Vendor section.
2nd: how many pulleys are in your "set" and are they the same Dia. As the stock pulleys? Do you include new belts with your package? If not and they are different sizes than stock.... how would one proceed?
please let me know..i am intrested.
Old Aug 30, 2007 | 12:52 AM
diablo1356's Avatar
how do you confuse witch and WHICH?
06g35
Feb 14, 2022 05:59 AM
brianuc4
19
Apr 10, 2020 02:12 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
sullivan72
Sep 22, 2015 11:39 PM
