FS: BC Cams, Valve Springs, Titanium Retainers
Old Oct 15, 2007 | 07:58 AM
drumma022's Avatar
I am selling the cams, valve springs, and titanium retainers since I recently traded my Z in. Everything is brand new in the box!
Brian Crower Stage 2 Camshaft Set. These cams will drop right in. ECU tuning is recommended for optimum performance but not required. Short duration for nice street manners, slight lope at idle. Excellent all purpose spec.
To my knowledge, the cams are currently compatible with the non-revup motors only.
Asking $1100 shipped within the U.S. Please email me for any questions - ziemba23@hotmail.com
Specs:
Adv.Dur. = 264/264
Dur.@.050 = 222/222
Lift(in) = .426"/.426"
Lift(mm) = 10.82mm/10.82mm
Spring Pressure:
BC1220 Seat: 1.425" @ 78 lbs
Open: 0.990" @ 192 lbs
Coil Bind: 0.900"
Attached Thumbnails FS: BC Cams, Valve Springs, Titanium Retainers-img_2435.jpg   FS: BC Cams, Valve Springs, Titanium Retainers-img_2436.jpg   FS: BC Cams, Valve Springs, Titanium Retainers-img_2437.jpg
Old Oct 15, 2007 | 10:04 AM
g35man04's Avatar
CLUB MODERATOR
so if im going FI on my 04 G35 coupe 5AT......how will this work for my engine?? Just curious?
Old Oct 15, 2007 | 06:10 PM
drumma022's Avatar
A 264 duration and the added lift provides a significant increase in power when you are FI.
Old Oct 15, 2007 | 07:17 PM
g35man04's Avatar
CLUB MODERATOR
okay...with that being said i would probably need to upgrade Pistons and rods as well...i have a 5AT....Will this kit my 04? I see that you wrote non-revup.
i am about to be putting on an ATI procharger.
Old Oct 15, 2007 | 07:22 PM
drumma022's Avatar
BC says that since the 2004 5AT was the non-revup, they will work.
Old Oct 15, 2007 | 07:31 PM
g35man04's Avatar
CLUB MODERATOR
okay. what else would you recommend??? how much is installation charge for something like this?
Old Oct 15, 2007 | 08:11 PM
drumma022's Avatar
Since I never got around to installing the cams on my car, I am unsure how long its estimated. IIRC, somebody on the forum was quoted around 8 hours labor.
I can also include any of the OEM gaskets that I have in my garage laying around. I will check on what gaskets I have and let you know.
If you are serious and have any other questions, you can email me: ziemba23@hotmail.com or AIM me: Enjuku Ray.
Old Oct 15, 2007 | 10:48 PM
g35man04's Avatar
CLUB MODERATOR
alright thanks for the input. I am just trying to figure out what i want to do...I have a 5AT and im putting a pro-charger on it and dont want to screw up the engine.
Old Oct 21, 2007 | 07:32 AM
Dustifer's Avatar
i sooo want these. wish i had the $$$ im a couple hundo short! :|
Old Jul 7, 2008 | 11:50 AM
specialist's Avatar
What kind of valve springs, and titanium retainers. And will you just sell them?
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
n2fooz
Sep 4, 2015 07:46 PM
UT G35
Sep 3, 2015 03:58 PM
