HID converson on stock 03 G35 sedan?
Old Jan 28, 2008 | 08:01 PM
nyqueenz's Avatar
how much or can i just buy an 05 headlights that come with blasts and plug up to the stock harness?
Old Jan 28, 2008 | 08:18 PM
Texasscout's Avatar
For about the same as buying the bulbs and ballasts. $400-$600
Old Jan 28, 2008 | 09:55 PM
black_sedan's Avatar
well, you'll have a pretty hard time getting those 05 headlight fitting on the 03-04 front end. might as well just get an HID kit to fit the housings you have or get an OEM HID setup from an 03-04
Old Jan 29, 2008 | 12:44 AM
Gian124's Avatar
I just put in the 06 coupe lights in my 03 coupe. I got them from Tony @ riverside shipped out. Fitment was easy and the install is cake if you know how to turn a ratchet. Search the forums, PM him for a price quote with shipping to your zip code. Was a good deal, fast shipping, and the results are quite noticeable.
The biggest reason to upgrade the whole light housing (opposed to simply putting in a different HID kit) is that the plastic headlight housings are brand-new again, with no sun-fading, etc... it is so blatantly noticeable. Really makes your car look newer and better maintained. If you are quite adept, you could always save money and wetsand the housings down... but you need time, tools and supplies to do it.
Old Jan 29, 2008 | 02:14 AM
g35ATX's Avatar
The sedan headlight fitment is different. 05-06 won't fit 03-04. I guess you could try to get some used set OEM HID headlights or an aftermaket HID kit but the cutoff beam doesn't look very good.
Old Jan 29, 2008 | 03:11 AM
dkhuynh's Avatar
since u dont have HID, i would do a projector lenses mod, ;D
Old Jan 29, 2008 | 09:19 PM
nyqueenz's Avatar
dose the 04 sedans come with HIDs? all i would have to do is swap out the HD asmblly...with an 04 .. but are the ballst plug and play with the 03 harness?
Old Jan 29, 2008 | 11:13 PM
lexusk8's Avatar
As far as I know, the OEM HIDs should directly plug in to the '03-'04 sedans as long as you have the HID headlamp assemblies (not the halogen ones as the design geometry is different for fitment of HID lighting). All '04 sedans have HIDs as standard feature (I believe the '03 base sedan model is the only one with halogen lighting as standard).
Jusseth
Sep 13, 2020 12:25 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
jimNC
Jul 25, 2015 05:47 AM
laksjd84
Jul 24, 2015 05:12 PM
attarday
Jul 15, 2015 04:03 PM
