FS: V-tube Z-tube larger diameter than oem
Old Jul 25, 2008 | 05:02 PM
  #31
ShanesG's Avatar
Originally Posted by infinitialex
it will flow more air compared to a z-tube,, if you look up what the diameter of intake pipe should be per given hp ,, in earlier 350z's an g35s intake tube is undersized ,, why do you think they went with dual intakes on later years?
That is not nessissarily true. Diff. materials have a different resistanse to air passing over it. So bigger diameter doesn't always mean better airflow.
Old Jul 25, 2008 | 06:46 PM
  #32
infinitialex's Avatar
surface resistance in smooth surface is so tiny that it wont make any differance
unless air is moving at hundreds of miles in hour
Old Jul 25, 2008 | 06:54 PM
  #33
CreativeDesignZ's Avatar
dude its 2mm...it looks like crap no1 would put this junk on their G unless they were messing around one day and made it as a temp fix.
Old Jul 25, 2008 | 08:22 PM
  #34
sure
Old Jul 28, 2008 | 11:46 AM
  #35
Project's Avatar
this doesnt even look long enough to reach the airbox even with the maf housing
Old Jul 28, 2008 | 12:15 PM
  #36
it might look shorter on pictures but its actually same exact length as OEM so it fits in there perfect.
Old Jul 28, 2008 | 02:54 PM
  #37
john@rabbid's Avatar
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
