Wheel buyers beware of Seller!
Old Dec 9, 2008 | 06:53 PM
  #31
Jeff92se's Avatar
Red Card Crew
Originally Posted by ILLMATiC G35
im not trying to be an @$$ but it kinda is your fault. knowing the rims were on widebody fenders then throwing them on your car and saying they dont fit. knowing them came off the car with wider fenders it would be common sense to figure they wouldn't fit on stock body specs...
IMHO he said they are from a coupe. Then he said rolling the fenders was recommended but not necessary.
On top of that, someone asked him about a coupe fitment pretty directly.
https://g35driver.com/forums/3368923-post11.html
Dude flat out said they were from a coupe.
Not sure what us a readers were supposed to take from the comments except for it should fit a coupe w/ or w/o rolling the fenders. (and I'd assume w/o it looking like a lowrider)
I mean really. Who was he supposed to be marketing these wheels to if clearly wasn't going to fit a sedan and apparently doesn't fit a coupe very well either?
Old Dec 9, 2008 | 06:54 PM
  #32
CandlestickPark's Avatar
ill Sedan
^This is what sweettalker posted in his FS thread:
"20x8.5 in the front and 20x10 in the rear. Came off of a coupe. Iforged does not release offsets."
Old Dec 9, 2008 | 06:56 PM
  #33
ShanesG's Avatar
^Oh yeah i forgot, well then it's almost impossible to say whether or not they will fit w/o off sets...
  #34
100wattz's Avatar
Originally Posted by socalvq
Small claims is less than $5000. Hence the name, small claims. I'm writing because I've had this happen to me. The only way to reach an amicable solution was filing the claim. They "get smart" real quick when they get that certified letter with the court date and their copy of the claim against them.
Do not modify the wheels in any way if you wish to reach a resolution. That's like buying a spruce tree, finding out the person really sold you a maple tree, and chopping down the tree instead of having them remove the tree and being able to resell the maple tree. You'd essentially be damaging his property and he would be able to file a counterclaim against you for doing so when you win your case.
ok, thanks for the help man. i need it!
  #35
G SEDAN's Avatar
I would guess that these have negative offsets. look how fat the lips looked compared to a regular aero setup on a coupe. it's only 8.5 x 10 also.
Old Dec 9, 2008 | 06:57 PM
  #36
ShanesG's Avatar
Pics of these on the car, with the car on the ground!
I say don't be a baby and camber the shiit!
Old Dec 9, 2008 | 06:59 PM
  #37
100wattz's Avatar
in his original post on his sedan you do realize he had widened the fenders in the front and rear correct? so it would make sense if they stuck out on stock body.. fyi
ya i knew that. but i dont have a sedan. he was asked if they will fit on a coupe and if so what needed to be done, all he said was to roll the fenders.
Old Dec 9, 2008 | 07:00 PM
  #38
100wattz's Avatar
Originally Posted by ShanesG
What are the specs of the wheels!?????
20x8.5 and 20x10. no info on the offsets cause he didnt have them, but my guess would be +0
Old Dec 9, 2008 | 07:02 PM
  #39
ShanesG's Avatar
^You can run +0 on both front and rear
Im running +4 in front on a 9.5" wheel!
Old Dec 9, 2008 | 07:07 PM
  #40
100wattz's Avatar
im not trying to be an @$$ but it kinda is your fault. knowing the rims were on widebody fenders then throwing them on your car and saying they dont fit. knowing they came off the car with wider fenders it would be common sense to figure they wouldn't fit on stock body specs...
i feel its my fault for trusting in what he said and knowing he was giving offsets. ive learned the lesson, and that is to not trust peoples word. obviously his clientele was g35c owners, right? not sedans, not sedans with widebody, not coupes with wide bodies. claiming they will fit on our cars to me is misrepresentation. for example:
i have a pair of shoes and im trying to sell them. i post that i dont have the exact size number but i can tell you i have big feet and the guy i bought them from had a size 12 shoe. when you get the shoes they are as described except they dont fit your size 12 foot. they are more like size 15.
might be a bad example but its all i thought of,
Old Dec 9, 2008 | 07:09 PM
  #41
jalilig35's Avatar
this cant be +0 offset, it has to be negative offset. anyone know if the offset is negative for sure???
Old Dec 9, 2008 | 07:10 PM
  #42
100wattz's Avatar
THANK YOU!
Old Dec 9, 2008 | 07:11 PM
  #43
100wattz's Avatar
then they must be negative then right?
Old Dec 9, 2008 | 07:13 PM
  #44
100wattz's Avatar
Originally Posted by G SEDAN
dont make the mistake of "shaving" those wheels down. That would be your biggest mistake #2
not that i am for sure gonna do this, but what would happen if i do. will it weaken the **** out the wheel? thanks!
  #45
ShanesG's Avatar
did you lower your car to the ground after you put the wheels on?
cause when my car is up the wheels stick out over an inch too!
