FS:Cipher Cable w/Software from UpREV
Old Jan 7, 2009 | 12:04 AM
03Sg35's Avatar
This is the Cipher Cable with software by UpREV in Austin. I used it for few weeks only. Some features of cipher
CIPHER -
Cipher is the diagnostic and data solution for the Nissan/Infiniti professional and enthusiast. Originally conceived for the 350Z and G35 after-market, Cipher decodes the Nissan/Infiniti specific On-Board protocol. Unlike OBDII, which is limited to EPA requirements, Cipher is able to access sensors and trouble codes that are otherwise invisible. Whether for service or performance tuning, Cipher lets you know exactly what your vehicle is doing. Using UpRev's proprietary cable interface and software, your USB equipped notebook becomes a cutting-edge service and data tool for today’s Nissan/Infiniti vehicles.
Key Features
Real-time sensor display - Monitor the condition of sensors and outputs.
Data-logging - Record and save data; sample rates of 20/sec with 16 sensors. Sample rate varies with the type and number of sensor logged.
Analytical charting - Review saved data with our integrated graphical utility or export the data as a csv file and create your personal charts.
Diagnostic Codes - Retrieve and clear the DTCs from each control module.
Configurable Target Ignition Timing +/- 2 degrees .
Configurable Target Idle RPM + 250 RPM (except for 2004.5 Z and G).
Adjust Ethanol Mixture Ratio
Cylinder Power Test
Fuel Pressure Release
Fuel Injection Test
Coolant Test
Below is a short list of available data parameters...
Engine Speed - RPM Throttle Position Sensor
Vehicle Speed MAF Sensor
Calculated Load Value Oxygen Sensor
Ignition Timing Accelerator Position
Wide Band A/F Voltage (2004.5+) Coolant Temperature
Price is set at 260 shipped plus 3% Paypal fee is used to pay
Pm me if intrested
Old Jan 7, 2009 | 10:04 AM
03Sg35's Avatar
Bumpy
Old Jan 8, 2009 | 10:51 PM
03Sg35's Avatar
Bump need this gone real cool toy to play with.
Old Jan 8, 2009 | 11:52 PM
Capthook's Avatar
Will this fit an 08?
Old Jan 9, 2009 | 09:26 AM
03Sg35's Avatar
I would double check with Uprev.com but it says on there most Nissan/Infiniti 2003 and newer.
Old Jan 9, 2009 | 01:59 PM
03Sg35's Avatar
250 shipped I have the new 64 bit drivers also
Old Jan 14, 2009 | 12:33 AM
06g35meister's Avatar
interested, need to know what the dicount is if any getting tuned with this... want the interface, but want the tunes as well... im in waco, tx
Old Jan 14, 2009 | 12:46 PM
03Sg35's Avatar
Im not Uprev, I do not know what discount if any they give out??Contact them. This cable however is not included in the tune they sell.
Old Jan 16, 2009 | 10:31 AM
03Sg35's Avatar
240shipped
Old Jan 19, 2009 | 09:55 AM
03Sg35's Avatar
To the top.......
Old Jan 21, 2009 | 09:56 AM
03Sg35's Avatar
Need this gone
Old Jan 23, 2009 | 08:41 AM
03Sg35's Avatar
235 shipped
Old Jan 23, 2009 | 09:24 AM
G35_TX's Avatar
The frontier forums and b15sentra.net had a few looking for this cable. Remember it works on all nissan/infinitis.
Old Jan 23, 2009 | 09:31 AM
diablo1356's Avatar
dibs
Old Jan 27, 2009 | 09:17 PM
03Sg35's Avatar
Still for sale
