F/S: OEM parts + speedo harness for 05
Old May 30, 2009 | 03:32 PM
Mr_pharmD's Avatar
Hi, I have oem parts that I no longer need.
1. MT clutch pedal assembly - 25 + shipping
2. AT brake pedal assembly - 25 + shipping
3. AT 05 console with led and side pieces - 100
4. Brake booster - 10 + shipping
5. Passenger Valve cover - 15 + shipping
6. 05 MT speedo harness where u can make ure 03-04 speedo into the newer one. It also has the navi plug. - SOLD
Old May 30, 2009 | 05:54 PM
Frankieg35's Avatar
Damn that harness won't work for an auto will it??
Old May 30, 2009 | 09:24 PM
Mr_pharmD's Avatar
yes it will bc I used my AT harness to plug into the MT speedo when I did my AT to MT conversion.
Old May 30, 2009 | 11:32 PM
Frankieg35's Avatar
with this plug i can upgrade my cluster to the newer one?? is it difficult to do??
Old May 31, 2009 | 01:09 AM
Mr_pharmD's Avatar
I had an 2005 AT and I got a MT cluster so I never used the MT clutster harness.
This 2005 MT cluster harness is good for those with 2003-2004 harness that wants to change out the cluster for the +05 clusters. I believe all u have to do is cut your 2003-2004 harness and connect the ends to the 05 harness and now u are able to use +05 cluster. I will have an 05 AT cluster for sale later on with 30K miles.
Old May 31, 2009 | 11:16 AM
Frankieg35's Avatar
how much u want for the cluster and harness?? i found a guy that can do the swap for me..
Old May 31, 2009 | 11:28 AM
Frankieg35's Avatar
so is the harness for an auto since it worked with your manual??
Old May 31, 2009 | 12:19 PM
tom's_Z's Avatar
If that is an manual harness it will require modification to work with your auto cluster, otherwise all of the tranny and check engine lights will turn on.
Old May 31, 2009 | 02:26 PM
Mr_pharmD's Avatar
All the wires there are color code so it should be that hard to match up or get the diagram from nissan.
All I can tell for sure is I had an AT... I use my AT harness (uncut) and it mated to the MT cluster without any issues. I believe it will only throw codes if u put in the wrong ecu type.
Old Jun 1, 2009 | 11:42 PM
Mr_pharmD's Avatar
ttt
Old Jun 3, 2009 | 10:13 PM
Mr_pharmD's Avatar
bump
Old Jun 29, 2009 | 04:33 PM
where are u located?
Old Aug 22, 2009 | 12:51 AM
Vincent Vega's Avatar
I want that Harness!!!!!! Please tell me you still have it????!!!!!
Xfactor
Dec 1, 2019 12:52 PM
mjfenix
Aug 17, 2017 05:49 AM
EPG35
Aug 16, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
