FS: Navigation Retrofit with Touchscreen
Old Feb 17, 2010 | 04:13 PM
rocsell's Avatar
NOTE: I should also mention that if you do not want to install a laptop to this, you can hook this up to a seperate DVD player and/or back-up camera...something you cannot do with the OEM screen unit.
Also, this unit slides up and retracts at the push of the button on top of the screen, just like OEM.
My CarPc project must come to an end as I need the cash and may have to sell my car.
I'm selling the Navigation chassis from an 06 Coupe...I removed the OEM screen and installed a Xenarc Touchscreen TFT LCD Monitor, model 700TS.
What this allows you to do now is to hook it up to a laptop (or CarPC) and run your laptop right from your touchscreen (install a Navigation program on the laptop or even a front-end such as RoadRunner).
The only issue I had with this is that the screen does not close all the way (probably sits about 1/4 inch above the closed position) and this is only due to the thickness of the wire...if you are good at soldering, then you can probably cut and solder the wires back together so that it sits flush.
The controls for the touchscreen are at the top, in the back of the screen (simply place a piece of black tape over the cut-out to hide this...you will still have access to the 5 buttons).
I would prefer to sell the whole unit together for $450...if you only want the OEM Nav chassis without the touchscreen, then I will sell this to you for $200.
I am also selling the NAV Control Unit (on another post for $200) which will fill in the gap that's left when you replace this chassis with the cubby-type chassis you currently have.
Send me your zip/postal code and I will calculate the shipping cost.
Attached Thumbnails Navigation Retrofit with Touchscreen-p2170538.jpg   Navigation Retrofit with Touchscreen-p2170543.jpg   Navigation Retrofit with Touchscreen-p2170539.jpg
Old Feb 17, 2010 | 09:40 PM
itpro2002's Avatar
this chassis is motorized?
Old Feb 17, 2010 | 09:41 PM
itpro2002's Avatar
Also is oem screen touch?
Old Feb 17, 2010 | 09:50 PM
rocsell's Avatar
Yes...just need to ensure the connector has IGN, BAT, NEG, ACC wires connected to it and it will lift up and also close up at the touch of the button on top of the screen (just like OEM)...I'm hoping to hook this up on my bench again and take a short film of this so that you can all see it in action.
Old Feb 17, 2010 | 09:51 PM
rocsell's Avatar
This is not the OEM screen...I removed the OEM screen and replaced it with a Xenarc touchscreen.
This allows you to hook it up to a laptop and/or DVD player and/or back-up camera.
Old Feb 17, 2010 | 09:58 PM
Glex25's Avatar
Administrator
I'll take the chassis once you have the video showing that is in proper working order
No dibs it's for sure that I'm taking it
Old Feb 17, 2010 | 10:09 PM
itpro2002's Avatar
will chassis fit in an 2004? ...I have factory nav but 04 not motorized
Old Feb 17, 2010 | 10:11 PM
Glex25's Avatar
Administrator
03-04 is different than 05-07
Old Feb 17, 2010 | 10:25 PM
rocsell's Avatar
No it will not fit in an 04...sorry.
Old Feb 17, 2010 | 10:26 PM
rocsell's Avatar
I hope to have this done on the weekend...
Old Feb 17, 2010 | 10:34 PM
Glex25's Avatar
Administrator
Hopefully I will be able to fit this screen just fine since it is also a 7" and since it is not touch the wires are much thinner.
You took the Xenarc screen out of its plastic shell to make it fit correct?
Old Feb 18, 2010 | 02:07 PM
rocsell's Avatar
[QUOTE=Glex25;4889159
You took the Xenarc screen out of its plastic shell to make it fit correct?[/QUOTE]
Yes, but that doesn't mean your screen will fit the OEM shell...you have to take your screen apart and fit it into the OEM shell, but there's no guarantee that your screen will fit this...I was patient enough and made sure it fit
Old Feb 20, 2010 | 10:41 AM
nyqueenz's Avatar
pmed
Old Feb 22, 2010 | 01:54 PM
rocsell's Avatar
My apologies in not getting to do a short video to show this unit working/functioning as promised, but I am off work on tuesday so I hope to get this done at that time.
Old Feb 24, 2010 | 01:53 PM
berniEE's Avatar
too bad its not for 04 id hop on this =[
