WTB: lower control arm and A arms
i need to get a front lower control arm and want to replace both of my front A arms but cant find any really good places to shop from and would also preffer aftermarket. Any suggestions?? Also my car is an 03 coupe... thanx
are you dropped? so dropped that your camber is out?
if so then get aftermarket arms, i would go for spl pro front A arms and rear camber arms if you are, they are pretty beefy but surprisingly light, pay the extra money and be safe
if you aren't dropped then don't bother unless they are worn out, just get oem's again
^ yes i am dropped on tien flex and have neggative camber. i am looking into getting some aftermarket A-arms with better style bushings since mine did get a pretty good beating. As far as control arm do you have any suggestions on brands, or just get another factory one?? btw my control arm did get a little messed up thats why i need to replace that too...
spl pro rear camber arms, spl pro front A arms, that is the best and safest combo you can get and they are beefy enough to take any beating, spl parts are not as over priced as stillen and make better quality parts imho, they are still pricey but well worth what you pay for
as for lower control arms, get factory they handle a lot of beating, just replace your factory bushing with polyurethane once they ware out
Alex Koss
Oct 29, 2021 12:53 PM
rezendvous420
May 31, 2020 01:26 PM
nineiron
Sep 10, 2015 12:08 PM
