Satellite Radio Antenna Mounting...
Old Aug 28, 2009 | 01:23 PM
hoffmbt's Avatar
So I installed the factory Sirius tuner a couple weeks back and when mounting the antenna I did what the directions called for...on the trunk lid. While I was able to live with it, it still bothered me that it simply just doesn't flow with the car well (nor does it anywhere else like the the roof). Not only that, where the antenna wire gets routed through the grommet connecting the trunk lid to the car, it was pinching and the pressure between the metal of the car and grommet caused the metal in the wire to be exposed. In effect I kept loosing signal for long periods of time (I think it was grounding out).
So I searched around the rear deck inside the car for a good mounting point and to my surprise found a great location! Check it out:
I removed the cover for this and my antenna bracket slid right on, very snug with no chance of shifting (I guess I lucked out with the shape of the bracket working so well). I get a great signal, the antenna wire can be routed a lot safer, and the location is very stealthy and clean. Just thought I'd give a heads up for anyone who may want to relocate their antenna, unless they already have a permanent mount on the roof...
Old Aug 31, 2009 | 11:11 AM
Bigd2k6's Avatar
looks perfect. might get some signal dropouts if you decide to get tint.
Old Apr 11, 2012 | 06:49 PM
Techre5's Avatar
wow, this is actually pretty cool.
Old May 6, 2012 | 11:13 AM
TheJanitor6203's Avatar
I installed mine here. It's completely stealth and the signal is still good!
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Sep 13, 2015 11:48 AM
