DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!
Old Mar 17, 2010 | 09:07 PM
GreenPenguin's Avatar
Hello guys and welcome to my DIY for the USA spec PA15-INF. I was tired of waiting for my favorite songs to come on the radio and hate lugging around cd's so I did my research and found this item on Cruthfeild for 149.99. It will charge my Iphone- allow direct control of music on the ipod itself or through any of the controls on the radio or steering wheel. I ordered it on Monday, it came on Tuesday, and I put in on Wednesday. This was a very easy install but time consuming because I took it slow. All in all it took me 2 hours. So make sure you have plenty of daylight to burn. Ive never done a tutorial before so if I'm not as in depth as you would like just ask me any questions you have directly.
So..... LETS GET STARTED!!!
Tools Needed:
Flat-head Screw driver
Phillips Screw Driver
Copper wire clothes hanger
zipties or anything to bind the excess chord
First thing first as with any install is to disconnect the negative(black) battery terminal- but before that unlock all your doors, open your trunk and move your font seats as far up as possible to maximize room in the back seat. Disconnecting the battery will prevent damage to the head unit or electrical shock while touching wire so you can like to mod another day.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-016.jpg
Now go to your trunk empty it out and start removing all the clips holding up all the trim pieces for the upper deck and side panels. Once all the clips are out pull down gently on the panel that is now held up by double sided tape to expose the stock sub and amp. The clips circled in red are what support the weight for entire upper panel.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-025.jpg
Remove the clips on both sides of the trunk access door and remove the grommet that lines the interior of the trunk access door.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-034.jpg
Old Mar 17, 2010 | 09:17 PM
I found it easier to remove these by inserting my hand in between the panel and support bracket and popping the clip out
Now lift the rear panel up as you pull the side panels out for the left then the right(or right then left)
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-024.jpg
Now go around to back seat and feel down near where the seat meets the carpet. Theres a hook tab that you want to pull towards the front of the car as you lift up on the seat. Theres on clip on the right side and one on the left. But be CAREFUL. I unnecessarily pulled to hard on the right one and snapped the hook.(yikes, jergens lotion anyone???)
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-017.jpg
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-002.jpg
Old Mar 17, 2010 | 09:27 PM
Now remove your rear seat by pushing the seat belt buckles down through their little slits and set everything aside somewhere out of the way.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-014.jpg
Now once all that is done your trunk should look something like this. The sat receiver wire is circled and is shown as a harness with a white connector.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-033.jpg
Now grab your harness that came with the PA15-INF and snake it through the nifty opening to the back seat area. (thanks nissan- that was easy!)
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-001.jpg
also a quick pic of the back seat
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-028.jpg
Old Mar 17, 2010 | 09:38 PM
The SAT wire harness should appear just beneath the lever to recline the back seat. The wire is about 6 feet long so pull through as much or as little through as you want. I am going to tuck all the excess wire under the back seat.
Attachment 117953
Now connect your female end of the harness onto the supplied male harness in your trunk and connect your ground wire to the metal chassis.
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-021.jpg
A quick pick of the trunk after grounding and harness connection
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-032.jpg
Old Mar 17, 2010 | 09:44 PM
Now for the fun stuff!!! I chose to run the cable that connects my iphone to the PA15-inf unit under the carpet- under the center console- and out of the center console to the passenger side. There are two screws on the side of the center console towards the back bottom. This is where the copper hanger came in handy!!!
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-015.jpg
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-020.jpg
DIY: Install USA Spec PA15-INF in 03-06 Sedans!!!-picture-026.jpg
Old Mar 17, 2010 | 09:46 PM
Calvin's Avatar
Overglorified Altima
Old Sep 18, 2010 | 07:21 PM
G35SedanGrn's Avatar
a little confusing but over all great! thanks!!
Old Sep 18, 2010 | 11:52 PM
codeflux's Avatar
Good write-up, albeit a bit confusing.
Huge favor - can you check if this lets you play music from apps other than iPod - say, Pandora or Shoutcast? /me subscribed
Old Oct 15, 2010 | 12:32 PM
codeflux's Avatar
OP's response, via PM:
Yes, it does! I play music from YouTube, Pandora, etc. Hope this helps!
I need to take a look in my trunk to make sure I have the SAT connector (I do have the SAT button, but just to be sure)...
Old Dec 1, 2010 | 01:20 PM
Goldie86's Avatar
I just got my PA15-INFI in the mail and I'm going to try and install it tonight...I have two quick questions:
1) If I disconnect the battery per step 1, will I lose my radio presets, memory seating, etc?
2) What is the best way to remove the trunk trim pieces without breaking anything? I'm worried about snapping the clips.
Thanks!
Old Dec 6, 2010 | 10:56 PM
AlexNY's Avatar
Thanks!
1) yes.
2) just use a small flat head screw driver.
Old Dec 28, 2010 | 06:47 PM
shawnhale05's Avatar
Very helpful! Thank you! I ended up having to drill a new hole with a self drilling screw to ground the unit, i couldn't find any screws that fit perfect.
where did you place the control box that you plug the wires into?
Old Mar 26, 2011 | 01:44 PM
Mp37G35C's Avatar
hi, can you tell me where did you conect the ground from the cable?
Old Mar 26, 2011 | 07:25 PM
codeflux's Avatar
i just stuck it behind one of the screws that connect to the metal frame behind the stereo.
Old Apr 3, 2011 | 03:07 PM
rayzah's Avatar
I did everything you said and i cant even get it to turn on. i have 04 sedan and I have the sat button , but when I press it it just sas not sat. what did i do wrong
