DIY 06 HU Removall
Old Mar 17, 2006 | 07:14 PM
Real_G's Avatar
An Army of One...
Originally Posted by seddon
This is exactly what I was looking for, even though I have an AT sedan it should be almost the same. Great job. Post pics when you are done with the replacement.
Replacement.. is the reverse order.. I just needed access to the rear of the Head Unit to connect my tvandnavtogo box and PA11-NIS.
Old Mar 17, 2006 | 10:03 PM
GRider35c's Avatar
Originally Posted by kappa1281
Do you have to remove anything before take the leather off? In other words, is this the first step?
Does the shift lock have to be fooled with?
yeah thats the first step...
Old May 13, 2006 | 06:09 PM
sd_diver's Avatar
1st step for 05 AT
... is to put the car in Neutral. I pulled and pulled to no avail at first. After that, the rest was a breeze. My only difficulty was in getting the HU back in after installing the PA11-NIS along with an internal 12V outlet. Had to move the outlet up to the nav cubby.
Old May 24, 2006 | 02:48 PM
churwitz's Avatar
Real_G - do you have any pictures of where you installed your PA11-NIS?
Old May 24, 2006 | 03:19 PM
Real_G's Avatar
An Army of One...
https://g35driver.com/forums/audio-video-electronics/86108-installed-nano-w-proclip-w-pa11-nas.html
Old May 31, 2006 | 01:45 AM
churwitz's Avatar
Woohoo! Thanks for the removal instructions Real_G, I installed the AAI-NIS2 today and all seems to be working. I only broke and lost 2 plastic clips down the back of the headunit in the process, but all seemed to fit together fine without em
Old Jan 5, 2007 | 01:43 AM
.:Brown Man:. J's Avatar
i know this thread is a while now but does the instructions fit for the 04' also?
Old Jan 5, 2007 | 01:52 AM
nm3th's Avatar
it's only for 05-06 sedan or 05-07 coupe.
check this out for 04: https://g35driver.com/forums/showpos...36&postcount=2
Old Jan 6, 2007 | 03:48 PM
Thank YOu sIR!! BIGG Help you just gave me
Old Oct 5, 2007 | 03:26 AM
xyzalvarez's Avatar
*booked
Old Nov 28, 2007 | 01:45 AM
KurtayKurt's Avatar
Finally found this thread ... been looking for it for awhile now. for those who were looking for it. heres a bump . also mods can you guys please move it to the DIY section? and prolly sticky it? thank you.
edit: also do i need to do anything to the shift lock? or do i just put it in neutral to remove it? (for an 06 AT coupe)
Old Dec 16, 2007 | 11:03 PM
PTownG's Avatar
great write up. I did it today. Broke 2 of those little white clips taking the clock shroud off but other than that everything came apart and went back together without a hitch.
Old Jan 2, 2008 | 05:14 PM
Real_G's Avatar
An Army of One...
Revisting my old thread.. remmoving everything to SELL!!
Old Jan 16, 2008 | 08:12 PM
alexchuang's Avatar
awesome thanks!!!
Old Jan 26, 2008 | 02:38 PM
  #30
bythabay's Avatar
this should be stickied.. it took me forever to find this via search.
