DIY 06 HU Removall
Old Feb 18, 2008 | 07:17 AM
  #31
cruze1209's Avatar
power 12 volt
I just bought a used G, couple months ago, and I've purchased a set of aux in set. I have a noob question, is there a harness for these 2 cable behind head unit? and where would it located? is it pretty obvious to see? I plan to install it this weekend, hopefully someone can help me out. Thanks
Old Feb 18, 2008 | 10:56 AM
  #32
Real_G's Avatar
An Army of One...
I cant tell what AUX adapter you have, but yes, when you remove the radio, you find various plugs and the wiring harness.
Old Feb 18, 2008 | 07:42 PM
  #33
cruze1209's Avatar
i bought the Axxess aux in set. And it requires the 12 volt. First time removing the radio out. Thanks for ur reply.
Old Mar 3, 2008 | 10:32 AM
  #34
ososlow24's Avatar
kool thanx
Old Mar 12, 2008 | 04:36 PM
  #35
OBG3506's Avatar
can we get a shot of the back of the stock hu? i have a portable sat radio i would like to hook up to my radio somehow!!
~Thx!
Old Jul 27, 2008 | 09:36 PM
  #36
lordhamster's Avatar
Thanks to this thread I just installed my Auxilliary hookup
I used the same PAC AAI-NIS2 as here:
https://g35driver.com/forums/audio-video-electronics/99632-pac-aai-nis2-ipod-adapter-installation-guide-05-dash-removal.html. Thanks for the help!
I was able to keep my satellite and listen to the iphone 3g at the same time! AWSOME!
BTW, this thread really needs to be stickied as it is great for those of use with the MT car.
Old Aug 19, 2009 | 04:46 PM
  #37
Locksmith's Avatar
Nice.
Old Sep 15, 2009 | 02:02 AM
  #38
likemystyleG35's Avatar
bumppp!!!!! very well done, thanks for going out your way to help everyone out! deffinately helped me & did it in like a hour! must need patience!
Old Feb 26, 2010 | 03:05 PM
  #39
ARSHAW's Avatar
Thanks Real G. This thread was very helpful.
Old Mar 28, 2010 | 05:49 PM
  #40
dealaddict1231's Avatar
Hi I did this install today and followed this pictures, worked like a charm. However I was wondering if the cigarette lighter in the G35 coupe 2009 6MT is 12 volts. I bought an Ipod to RCA with charger but unsure it it will work because it says I must connect to 12 volt source. Thank in Advance.
Old Mar 28, 2010 | 05:57 PM
  #41
davidxu's Avatar
yes. its 12 volts
Old Apr 26, 2010 | 03:51 PM
  #42
tho's Avatar
tho
Another post of thanks for this thread. I got my PAC NIS2 installed in about an hour.
TD
Old May 10, 2010 | 04:04 AM
  #43
or_G's Avatar
i can easily do this, but i dont know how successful im going to be with all of the wires
Old May 10, 2010 | 08:19 AM
  #44
tho's Avatar
tho
What do you mean by this? The wiring is plug and play. No soldering. There is a spot down where the ash tray is, where I shoved the unit itself and there is a little less room behind the radio because of the extra plugs so it makes it a little harder to push the unit back into place but it fits.
Old May 19, 2010 | 09:37 PM
  #45
scouzi's Avatar
Thanks!
Just installed mine as well. Just broke one clip on the side panel.
Connectors are hard to take off.
