Manufactures that make amps that accept balanced-differential signals?
Old May 26, 2006 | 08:22 PM
SithSolo1's Avatar
I know JL Audio and DLS do but does anyone else?
Old May 26, 2006 | 08:35 PM
k67p67's Avatar
Zapco
Old May 26, 2006 | 09:23 PM
Ivory056MT's Avatar
My alpine and PPI amps both work with the output of the blose radio. I don't know about that balanced-differential crap.
JH
Old May 26, 2006 | 11:10 PM
SithSolo1's Avatar
Which alpine are you using?
Old May 27, 2006 | 10:27 AM
murzik's Avatar
Infinity works fine.
Old May 27, 2006 | 04:28 PM
redlude97's Avatar
Which infinity amps did you use specifically, and you just tapped RCAs into the lines before the bose amp correct?
Old May 28, 2006 | 01:26 PM
Ivory056MT's Avatar
Yes, you can find the tech specs for the wire colors here on the board, I don't remember exactly where. The inputs to the amp are sheilded so the 4 leads are obvious.
I'm just using a standard 40 x 4 alpine I got from Best Buy. I'm pretty sure almost any amp would work if it was hooked up correctly.
JH
Old May 29, 2006 | 08:45 PM
redlude97's Avatar
Can anyone else confirm that Alpine amps accept balanced inputs?
Xfactor
Dec 1, 2019 12:52 PM
Frostbite91
Aug 2, 2015 04:59 PM
stay_tuned
Jul 21, 2015 07:09 PM
