How do I install subs/amps in coupe and make em harder to steal.
Old May 31, 2006 | 07:30 PM
f50bodykit's Avatar
Hi,
I was wondering if anybody implemented this in their setups. I want to make it hard to steal stuff. A lot of the setups in here it looks like it would be easy to just pop the trunk and take some of this stuff. Is this the case? If so what are some things that I can do to make it harder to steel the equipment. Any info would be great. I'm getting ready to start doing my own install for the first time.
J
Old May 31, 2006 | 07:33 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Bolt the box to a peice of MDF and bolt the MDF to the car. Make sure if you drill through the car you dont drill into the gas tank.
-GP-
Old May 31, 2006 | 09:44 PM
redlude97's Avatar
You could use torx bits to secure all your equipment, but seriously, if they are already in your trunk, its probably better if they can take it easily, if you make it too difficult, they may just do more damage to your car trying to rip the equipment out
Old Jun 1, 2006 | 02:01 PM
f50bodykit's Avatar
Does the alarm go off, if the trunk is popped open?
Old Jun 1, 2006 | 10:38 PM
blazinZ's Avatar
better alarm...
Old Jun 1, 2006 | 11:05 PM
DHCrocks's Avatar
bolt it down to the floor pan using bolts and lock nuts (the kind with the plastic inserts). Using those will require a wrench on both ends one in the trunk and the other under the car. Another option would be to use phillips lag screws and drill out the head, you'll need an extractor to remove those.
Old Jun 2, 2006 | 10:37 AM
Gilley's Avatar
don't play your music loud in places that will get you noticed so they know you have something to steal in the first place. Second, go stealth and hide everything you can. And don't put stickers on your car advertising what you have.
Old Jun 2, 2006 | 11:14 AM
Espresso's Avatar
Rig a tear gas canister to your trunk equipment. That should do the trick.
Old Jun 2, 2006 | 12:44 PM
machavez702's Avatar
Get a dog.
Old Jun 2, 2006 | 01:31 PM
KPierson's Avatar
Build your entire setup to fit the car, hiding all structual screws. My last setup got broken in to and all they could do was look at it all, and walk away.
This was a '94 Cavalier that had (3) 12" subs in it. I built 3 individual boxes and then actually bolted them together IN the trunk. The assembled box would not come out, it was too large. The box was also blocked by the amp rack, which was sitting under a piece of 1/4" plexi and a trim piece. The amps actually would have came out easy, but I don't think they had the time or wanted to risk making the noise necesarry to rip everything out, as they broke in to the car in my driveway in my neighborhood.
My first car that ever got broken in to had (4) 12" subs and two separate amps. The amps were mounted to the box, and the box was just sitting in the trunk. They popped my trunk, cut the wires, and pulled everything out and were gone. After that experiance I decided to integrate everything in to the car so it wouldn't be as easy the next time.
Old Jun 13, 2006 | 08:24 AM
SURFJ9009's Avatar
Thumbs up
Just leave a dead body in there too. That will stop just about anybody in their tracks.
Xfactor
Dec 1, 2019 12:52 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
multimut
Canada
Jul 26, 2015 08:43 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
