Where can I buy DLS equipment?
Old Jun 12, 2006 | 12:25 AM
BigSash's Avatar
Originally Posted by dukieman23
hey jmlaudio and elduderino,
i was wondering if you guys have ever installed a pair of DLS UP6 and some coaxials rear fills using the RA40? i currently have that config but my gain on the amp is turned to the max and the sound in my car isnt unbelievably loud or anything, my gain is at max and so is my volume control on the stock HU... although DLS are more for SQ but the SQ now isnt THAT great either..will check the phase in a bit. (btw, how do u check the phase on the tweeters? is the wire that has a stripe on it generally positive?, i cant distinguish +/- on the tweeter).... Was wondering if this amp is underpowered for this config, i know a lot of ppl just went w/ the R20 to power the UP6's instead. Maybe it just needs a little bit of tuning? Any suggestions would be appreciated. thanks.
I have that setup with the ra40 gets loud as ****
Old Jun 12, 2006 | 01:23 AM
dukieman23's Avatar
i hope so BigSash!! i am gettin some RCA's via mail order on tues/wed. so hopefully i'll have it hked up before the wkend and will yield WAAAY better results. thanks elduderino for pointing out my goof. btw, im tempted to just test it out w/ some monster cable RCA's i have lying around but it's kind of short, would it still work if i tapped the incoming input differential signals before the bose amp w/ regular 16ga speaker wires and then connecting the end of it w/ my RCA wires and then to my amp?
Old Jun 12, 2006 | 09:58 PM
dukieman23's Avatar
all i can say is WOW. i connected my rA40 using some rca's 15min ago...i'm grinning from left to right and up and down...thanks elduderino and all the other ppl on this forum for recommending the up6's. they are sweeeeeeeeeet! i havent even tuned the system yet... havevnt adjusted the input sensitivty and the filters...wut freq do you guys have it on??
toadfire
Sep 21, 2015 07:15 AM
RA081024
Sep 18, 2015 12:20 PM
dorifto7
Sep 17, 2015 04:53 AM
mamba24
Sep 15, 2015 10:37 PM
twentyeggs
Sep 11, 2015 03:58 PM
